ABS removal
ABS removal
is this a simple way of removing the abs on an s2? it looks like the pipes are just bypassed on the master cylinder, can the pumps then be removed or do the lines go through them ie the belts can be removed but the pumps have to stay?
no need to replace the whole lot for sure, just pipe them from the resevoir to the pipes before the t-piece split sections on the inner wing and lower bulkhead.
then chuck the old ABS crap in the bin
