non turbo block
just bought meself a S1, with a buggard engine.....
i was wondering if i can use the bottom end of a non turbo 1600 cvh, as therer seems to be more of these around.
if anyone can help me it would be much appriciated
Don't know what you want but if you want to convert a non turbo to turbo with turbo pistons yes it can just get the oil feed from your RSt engine and make a oil return in the sump and place the turbo pistons in it.
I have done it - piece of piss to get the hole for the drain drilled in the block.
I got the CPS hole drilled in mine at the same time to allow me to run Fiest Turbo EFi...
JK12
33
26-04-2021 12:09 PM
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
