PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. 17" fittment
  2. Electric door mirrors
  3. change of colour
  4. Info on Newman cams
  5. Eruption 101.3 FM Tonight 8pm tll 10pm LIVE STREAM
  6. throttle cable???
  7. Another Ebay Ringer!!
  8. Head Knocking?
  9. WHATS THE GAINS OF SOLID LIFTERS/SOLID PROFILE CAM
  10. thinking of buying these
  11. thinking of buying these ?/
  12. Brakes For The Series 2
  13. who uses aerocatch??
  14. Series 1 RS Coolant Sensor Prob
  15. newbie ABS question
  16. ZVH, ZETEC..... whats what??
  17. spray job in bpool
  18. inlet manifold ???
  19. help needed with s-1 parts
  20. Under bonnet photo's
  21. s2 starter motor alternatives
  22. my escort cos rims any1 want to swap me for 17 voodoos
  23. S1 Aternator
  24. Bonnet Lifters ?????????
  25. any one with a roll cage
  26. Pics of my s2 just done my wheels
  27. Doors seals / weather strips
  28. Picture Request S2 Boot Install
  29. http://www.zvh-zetecturbo.co.uk/
  30. 17 inch wheel ofset
  31. WILL ERST START WITH THE THROTTLE SENSOR DIS CONNECTED???
  32. s2 green tint opening rear quaters
  33. Map Sensor
  34. COSSIE MANAGMENT
  35. What gearboxes can i fit in a mk3???
  36. Need help
  37. Misfire on S2 RST - Help Please!
  38. oil smells of petrol
  39. S2 wheel colour??
  40. JUST ORDERED THESE ANYONE ELSE GOT THEM?
  41. doing a restoration
  42. NO SPRAK ERST help!!!!!! :'(
  43. Wandering car??
  44. oil
  45. RS turbo gearbox suggestions
  46. Wolfrace voodoos
  47. inner cv
  48. ANY 1 USED TO OWN THIS ERST
  49. the rails on the mk3 and mk4
  50. ACTUATOR
  51. sill panel
  52. what choice do i have for turbos
  53. using water/coolant- pics added
  54. sooo pissed off update
  55. drive shafts
  56. efi loom wire where???
  57. Lifting eyes
  58. inlet gaskets
  59. Stuck caliper
  60. Suspension possibly forked ?
  61. 60mph
  62. WHAT IS THE RIGHT ENGINE OIL FOR A ESCORT RS TURBO?? HELP=(
  63. s2 fuel tank
  64. Got S1 back with new panels on!
  65. photos of my s2 ill try again ha ha
  66. photos of my s2
  67. possible ecu fault ?
  68. how strong are black diamond clutches
  69. fitted 17's but rub on fronts.. PICS ADDED
  70. good news and bad news
  71. who needs a stronger clutch for big power??
  72. s1 custom question
  73. rs turbo wheels dilema
  74. gearbox oil
  75. just call me the daddy when moding dump valves (RESULT)
  76. is a hearts, dimonds,crosses ecu ok for an s1
  77. adjusting the fueling
  78. oil pump seized??
  79. headlight prob
  80. Part number needed???
  81. snapped piston rings
  82. need new discs
  83. big brakes
  84. High Idle & Injector hissing
  85. Brakes
  86. how strong are the standerd rs boxes
  87. wheres the heater reostat?
  88. turbo systems ecu
  89. Computer + Boredom = Animation! Edit: And another!
  90. fao mr. safe chav/or any ecu guru's***pic added 08/01/07***
  91. roll cage? customs breaklines? where?
  92. WHAT IS THE GREEN RELAY FOR UNDER THE DASH OF A S2
  93. s1 wheels
  94. piston ring price
  95. escort not bin started for abit
  96. throttle cable
  97. Urgent Help Req - 1800 pulley
  98. ST170 BRAKES HELP!!!
  99. oil pressure gauge
  100. dump valve confusion
  101. ecu fault??
  102. stiff steering
  103. Flywheel Bolts
  104. escort 1/4 mile times
  105. radiator leaking
  106. home made short shift
  107. 1 Bar Boost!!
  108. cabriolet
  109. Buying another series2
  110. quick shift
  111. new radiator?
  112. what bhp can i get
  113. Radiator fan wiring
  114. exh hanger part number?
  115. Steering Rack
  116. s1 anti roll bar on s2 without using the mk3 box
  117. Failed my MOT
  118. flat S2 - any ideas?
  119. Has anyone got the original Escort RST TV Advert
  120. s1 sunroof help
  121. Vid from PF Thrash.......
  122. s2 fuel pressure
  123. Escort rs turbo bumper strips
  124. how do you get the rad out of an s1
  125. That I need pieces for this change?
  126. wat clutch
  127. american tall block cps location...??
  128. Turbo Timer - any one fitted one
  129. Chester RS TURBO S1 ?
  130. RS TURBO ADVICE
  131. What Chip is this
  132. Please help. to much fuel
  133. what turbo for roughly 270 bhp?
  134. Any one know anything about G555 GWP? Red s2 turbo.
  135. please delete all sorted
  136. new site to try
  137. Engine problem
  138. Spark Plugs
  139. feul problem
  140. FAO APT boys: Christian or Tony
  141. may have been asked before anyway........zetec turbo or zvh
  142. series 1 or 2 please read
  143. Engine rebuild...........
  144. oil coming out of the dump valve
  145. need a good painter in the staffordshire area
  146. S1 in Fast Car a few years back....
  147. mk4 indicator bolts
  148. 280 BHP 1.6???
  149. cold start problem help!!!
  150. Water Tempture Gauge
  151. brake pipe kit
  152. Willwood Brake kits
  153. Partners Recent Spec Change
  154. Pic of a mint 88 spec interior?
  155. what size speakers will fit in my mk4 cab?
  156. NEED TO REPLACE MY SHOCKS AND SPRINGS ADVICE
  157. s1 strut brace
  158. HELP!!!!!
  159. try again pic of my left hand drive rs turbo
  160. pics of my left hand drive turbo
  161. escort rs turbo sump??? HELP NEEDED
  162. pics of my lhd rs turbo
  163. pics of my lhd rs turbo
  164. Battery light on very faint
  165. Badges..............
  166. Any ideas on this RS?
  167. who makes these please
  168. Main bearing Caps
  169. Headgasket
  170. boost control?
  171. pic of my s1
  172. Anyone on here own my old S1.............
  173. photos
  174. Boost Gauge
  175. Car Stereo
  176. Looking For Info On H242 ***
  177. pic request of rear wishbone to hub poly bushes
  178. cant spell
  179. Intercooler fans
  180. Master brake cylinder
  181. BnM shifter
  182. s1 sticker kits???????????
  183. cams, what do you recomend
  184. Gift from Santa Claus
  185. Manual Boost Controllers
  186. best ported cvh head
  187. chipped ECU
  188. RS7's
  189. -34
  190. wastegate at stop but only running 6psi with -31 actuator
  191. Alloy Radiator....
  192. thermostat
  193. picture request of black number plates on a series one
  194. ecu questions
  195. New to RS ownership! advice
  196. black rims?
  197. Do people use rear strut brace
  198. so at what stages can you run higher boost?
  199. an advice on headgasket felpro
  200. Weird Idle
  201. Oil pump
  202. lookin at wheels
  203. wat psi on standerd engine
  204. Merry xmas
  205. are s1 and s2 fuel ecu the same?
  206. what alloys are these?
  207. cabriolet roof cover.
  208. mondeo s rims
  209. PINK FUEL RELAY IS THE XR3I ONE AND ERST ONE THE SAME????
  210. gave the s1 a cristmas present
  211. erst head
  212. clicking noise when turning
  213. Which Headlight Bulb's
  214. s1 rst will not idle when warming up
  215. anyone know the ware abouts of C400BHX s1 rst
  216. going efi
  217. Fusebox problem!
  218. part number for standard head gasket
  219. exhausts?
  220. Ideas on s2rst that needs big revs to move from standstill
  221. Which bore exhaust, I'm confused now!!
  222. rs turbo roll cage
  223. help please,fuel pissing out of d.v and everywhere
  224. how much for an alternator
  225. Everyone with a 1.6 RST...
  226. thermostat housing.
  227. Engine Mount
  228. ERST LOOM HELP PLEASEEEEEE :'(
  229. wat next?
  230. top speed on 18s ?
  231. lift hight of a standard s1 cam????????
  232. Project RS Kicker back on ebay
  233. Fitting a swirl pot
  234. rs turbo thrash
  235. Ke-Jetronic hoses
  236. how fooking much!!!!!!
  237. One side light?
  238. sensible power mods
  239. speaker size?
  240. my car dosent feel like its boosting properly
  241. what other gearboxes fit the s2
  242. is my car efi or mfi
  243. Not Again!
  244. help with twin headlights
  245. tailgates
  246. BIG PROBLEM- Car is slow on 1 bar !!!
  247. Big Brake Kit for the S2
  248. chiping s2
  249. ESCORT MK4 NUMBER PLATE IN REAR BUMPER PICTURE??
  250. Come peeps big it up for the FWD ERST
