Failed my MOT
Failed my MOT
Failed the MOT today on the S1....gutted.
spent £250 last month on the steering rack and track ends ect.
not to bad though, main bit was £150 welding to be done Friday.
couple of bulbs, adjusting main beam, new suspension bush and my CO2 is double the fail rate.....
told em to do the work and turn the emmisions down, so car back next week probally.
The failed emmissions, what is that down too?? is it oil seals and metering head??
and if its the metering head can the re-build kits cure the problem or would you need a new metering unit?
cheers.
bet my bill tops £200
cheers.
As above, dont be giving it much slipper after your mot, you could be running too lean and end up with melted piston!
I would get it booked in for a diagnostic/setup asap after your mot.
Originally Posted by Mixja
my s1 failed the mot on co2, fella just turned down the mixture screw till it was back in line... when i got me ticket, i wound it back up 1/4 turn...
S1 Database Editor
Originally Posted by NUTS RuS
I got 2 for £30 from my local place, new old stock they were just happy to get rid of them
Wanna sell one?? Give you £30 for one..100% profit
Gutted for you mate
You think it's time to cut your loses with this one and wait till the summer for something thats not going to give you so much hassle?
S1 Database Editor
Ford ones with stamp and number
It went on Ebay for £45 and I have the other on the car, whilst the qwikrak is being serviced
SMILER258
28-09-2015 09:04 AM
