Need help
Old Jan 9, 2007 | 05:56 PM
kurdt5's Avatar
kurdt5
Default Need help
Got my car back today after a week in the garage. BUT......
its running rough again. Last time i collected it from the garage it hadnt been started for a week and when i picked it up it ran rough, putting and hard to drive....kinda like one of the ht leads has fallen of the dizzy.
picked it up today and its been sat a week and is doing the same thing.
Last time i got charged to rectify this it needed a new...dizzy, ht leads and spark plugs..THAT was only last month.
So i checked the leads were on...spark plugs look new still, nothings wet and inside of the new dizzy is dry.
Could my ht leads be gone again????
i usually start the car every 3 days in the winter and its fine.
any help will do.......OH Yeah.....they turned my screw to lower the CO so it would go through the MOT.....could this just need turning back???
car hasnt been ragged by them either....i left it on 3.6 miles on the clock, it reads 3.7 when i collected it.
Old Jan 9, 2007 | 06:16 PM
rustyrs's Avatar
rustyrs
it will be the co to weak .these cars dont like it weak.ajust the co 1/4 of a turn clockwise
Old Jan 9, 2007 | 06:19 PM
davidnormanuk's Avatar
davidnormanuk
http://www.escortrsturbo.co.uk/forum...0&#entry115248
This works a treat. I've set loads of RST's up like this and it works a treat.
Old Jan 9, 2007 | 07:15 PM
SafeChav's Avatar
SafeChav
bad luck mate
I doubt very much its anything gone, HT leads and plugs should last a LOT longer than that.
However one thing i would say, starting the car up and letting it idle isn't really doing it any good, it wouold be better to just leave it sat and disconnect the battery, and start it less often and take it for a good drive so it gets up to temperature and doesnt foul the plugs up from the cold start mixture.
Am i right in thinking you compression tested it last time?
Old Jan 9, 2007 | 07:41 PM
kurdt5's Avatar
kurdt5
yeah safechav i did, it was all fine.
just the same problem as last time...standing a while not started and now playing around again
Old Jan 9, 2007 | 07:45 PM
SafeChav's Avatar
SafeChav
You shouldn't really have these problems mate
Something is a miss but it will onyl be something silly. I left my cabby on the drive for about 2 months and it started no problems, you shouldnt have to keep starting it if you get me
Have you considered having it rolling roaded?
Old Jan 9, 2007 | 08:42 PM
gup's Avatar
gup
did it try and cut out at all or was it just jumping when coming on boost have you checked your plug gaps too also the silver tip comes loose too
