pic request of rear wishbone to hub poly bushes
having problems fitting my poly bushes to the rear wishbone outers
thanks in advance
thanks in advance
now i am confused , they look totally different to mine , is the one in the very bottom left the same as the one just above it just taken from above ?
also have you a pic of it in situ ?
cheers
its the only ones out of the whole set i am having probs with , any chance you could measure the bush from the inside of the flange bit to the end , got a feeling mine are too short
Originally Posted by NUTS RuS
whats the problem your having ?
if that makes any sense to you
mine are defex so i am being very cautious with them and will go measure them , did yours come with a fitting guide or anything ?
its a little bit small but where the diagram is showing the length is 2.5cm mine is 2.3cm and looking at mine when its fitted in the wishbone it is much more than 2mm from poking out the other end so i don't think that's it , surely it wouldn't be metal on metal but i cant see any other way it fits together
Cant get my head round what you mean... your not fitting the rear tie bar ones in are you ?
hope this helps , I'm not too good at explaining myself
rolf harris eat your heart out (its color coded cuz the text bar wont come back either
overhead view
dark grey is the hub
light grey in the wishbone
yellow is the bushes
red arrows pointing to bit where it is metal on metal
overhead view
![](https://i137.photobucket.com/albums/q229/yadayadayadayada/bush.jpg)
Ahhh the diagram shows it clearly now
They have to be the metal/metal flush fit as there is no room for a second bush there. Just 1 in each outer end as shown.
I understand that - but fail to see what the problem is ?
Are the tubes too long or short or something ?
Its the only way using a standard upright.
Even my rose jointed ones are metal/metal
![](https://img.photobucket.com/albums/v53/tij909/b09b3c84.jpg)
In my earlier type I did have a solid nylon bush in there, but even that was sleeved with metal, so the inner bit hes on about was still metal/metal with a solid nylon bush.
![](https://img.photobucket.com/albums/v53/tij909/05537303.jpg)
That long shiny bolt is the bolt he refers to - I just got rid of the crap wishbone design
i had solid nylon ones in that at both ends too. All this coloured rubber stuff is no use for motorsport ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
p.s nowt wrong with my drawing
jessie_rs
11
03-06-2019 04:57 PM
Wilsfoci
15
30-03-2016 10:26 PM
09-10-2015 07:38 PM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
