Engine problem
Old Jan 2, 2007 | 12:20 PM
Dragsteer's Avatar
Dragsteer
Default Engine problem
Hello
Before few days I setting CO screw, and since then car is dont want to idle correctly, I must push throttle pedal or engine will cut off. Rmps dont want stay on 950 they fall and car turn off. and when I drive I have detonations from exhaust.
Anyone has idea?
Maybe injectors??
Old Jan 2, 2007 | 12:22 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
So, are you saying that you set the CO screw?
If so, the setting is probably wrong. It's now something you can do without the correct equipment/knowledge.
Old Jan 2, 2007 | 12:25 PM
Dragsteer's Avatar
Dragsteer
I go to frend with co meter, and I set it at about 1.45%
Old Jan 2, 2007 | 12:28 PM
Christian and Beccy
#1 in Spelling Club
Too lean IMO. That would explain the banging.
Old Jan 2, 2007 | 12:40 PM
Dragsteer's Avatar
Dragsteer
How much I must set ? about 2% or?? Thanks
Old Jan 3, 2007 | 12:14 PM
Dragsteer's Avatar
Dragsteer
One thing : When engine is cold it work ok, but after about 1 minutes, engine starts worknig like somewhere is air leak, revs go down and engine will turn off if I dont push throttle
Thanks
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
