1 Bar Boost!!
1 Bar Boost!!
Hi, i am about to purchase a erst s2!!
The fella i am buying it off says it is running 1 bar boost - which i hear using as an every day car is not such a good thing!! (he has had it as a project and a toy really - weekend drivng only he says!!)
Bassically i was wondering if it is possible to change the boost bar to a better/more usable - and what boost is advisable to use for a dialy driver??
I am very new to Turbo cars so any help would be much appreciated!!
Another quickie - would anybody be able to list what things i should change at what time to keep the car running sweet!!
Cheers,
Dumpy
Cheers,
Dumpy
you can adjust the actuator rod m8 shortening turns up the boost lenghning turns down the boost,
or buy a boost control of ebay about 20 quid
but just check this with some1 on here to make sure i got that the right way round m8 about the rod
Custom
as above mate
i ran my old standard rs turbo everyday for 4 years at 1 bar boost with no problems
as for keeping it running sweet
change the plugs - ford motorcraft 071s or ngk bcr8es
new oil - fully synthetic
oil filter - ford
fuel filter - ford
and a full rolling road setup
oil filter - ford
fuel filter - ford
Ive been running mine for 7 years at 16 psi with no probs at all get it set up once every year and service regulary and it should not give you any grief.
As said ... I run mine on 1bar as a daily and have no problems with it, and it'll only boost that high if I intend to floor it, which I don't do everyday.
Cheers for your resposes!!
I shall keep on to of servicing etc probably quaterly - around 3k, oil etc - then cam belt probablt every 9 months or year!!
I dont really put my foot down too often so all being well i shall have no problems!!
Cheers again,
Dumpy
Cheers again,
Dumpy
I run mine on 19PSi, with standard intercooler. Never gone wrong. Had it 2 years now, Daily driver. Taken some abuse! But regulary serviced. Im pretty sure all internals are standard etc. But since end of last summer i been running the switch boost as mentioned above.
Custom
how the hell does that stay together my mate ran 18 psi with standard intercooler it melted the pistons in about 5 mins
Don't mention ze Vor
About 18 PSI here
- chipped ECU (obviously)
- std actuator at the moment (uprated one to be fitted soon)
- bog std internals and head (90000 miles)
- self adjusted fuel-pressure actuator (yeah, I'm nuts... :P )
- std intercooler but front bumper cut out and spotlights removed to allow better air flow. Gonna fit an Audi TDI intercooler soon.
It's a track car though, no daily runner. But when it's driven, it's driven hard.
No problems so far *knockonwood*
No jerking, cutting-out, hesitating whatsoever. Not bad for a DIY test object, eh?
Originally Posted by PeterRST
About 18 PSI here
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
