- h352 gec red escort
- Cruise AFR's?
- What EFI inlet?
- Wrong camshaft?
- Fuel Pump Floor Mount
- Thinkin about another S2
- Steering lock?
- whats involved in runing a yb engine on a front wheel drive set on a rsturbo??
- what would you do..
- turbo coolant pipes
- no oil light or handbrake light on dash
- 8j x 16 wheels
- This gearbox any good then???
- Removing dump valve
- S2 Bumper trim
- Missfire on boost
- Hub question(painting)
- need help findin a good place 4 a set up!!
- Need an LSD box...
- A few ZVH questions...
- RS Turbo problem
- Anyone know where my old rst is????
- Oil temp and pressure gauge
- Which Rad
- zvh
- New Servo or upgrade?
- Rev limiter?
- Crank position sensor holder EFI rs turbo
- oil cooler thingy?
- fuel pressure
- Removing locked petrol cap
- engine mount ?
- Car is finally MOT'd and on the road!! Also some mapping info!
- Bonnet raisers yay or nay and do they actually do anything??
- turbo
- 40mm gmax springs
- What Breather?
- Who is hiding all the recaros??
- gearbox problems
- the s1 is staying ... would like a big spec engine.
- 1.6 Carb and XR3i fuel tank differences?
- part to repair collapsed recaro?
- what sort of compression for a 1900 cvh
- 0-60 times and power/torque no bullshit please
- S2 Polybushes
- what paint, matt or gloss for under bonnet parts
- Electr. mirrors removal in rst and fuel pump cradle question
- what would cause pistons to crack?
- cosworth disc and caliper question sorted
- Adjustable fuel regulator on mfi?
- inlet manifold for zetec turbo help
- rough idea of powdercoating prices
- escort RST bump stops?
- Fuel pump cradle
- Efi block. Whos a lucky boy?
- s1 rs turbo gear box
- Are these rare?
- mk4 cards on mk3 doors
- FAO D4RST
- is d4 going to come up with the goods?
- Fiesta brakes on an ERST?
- oil filler cap!
- Some EFi fuel system questions
- will a piper 285t2 cam be alright with a standard cam wheel?
- how do u tell the diference between a single piston bailey dumpvalve+a twin piston dv
- 8x16" comps
- Tony turbo selling his legend of a car..
- (HELP) ANY1 in the southend on sea area
- series 1
- fiesta rs fuel pump s2
- 10/10 gutted
- do the pins come out of the door or do i have to take the door off?
- Drove my car for the first time today!!
- header tank
- Drive shafts
- G25 UUE , anyone know this mercury grey rs turbo???
- rs 7 spokes
- Turbo spec any good?
- how to fit cossie fwd how to mount ect and what box.
- Escort rs Brake Hose Problem
- Bad radio signal??
- Starting problems
- OMG Got my car mapped @ MSD
- RS turbo green relay?
- Central day weekend camp over?
- Airtec front mount cooler(all sorted)
- do series ones have the yellow plug on the inlet???
- easiest DIY management
- ALS valve
- suspenison swap
- Series 2 Rear Lights
- few goodies
- distributor
- RST Interior
- Hyperthetical engne idea, to all the engine builder out ther
- Fuel Filter and Pipes
- fixing reverse gear
- Zvh keeps blowing seals in head
- Missed my rs
- anyone no what happened to G67 HAB
- C20XE Pistons
- Anyone Know This Car????
- How can i flush out any crap buildup in water system
- Fitting a group a coil to a series 2
- who makes these crank trigger wheels?
- RS Turbo Wiring Diagram
- Escort 1.8 to RS Turbo Converstion
- 9K
- Problem with the MFi system!
- what size brakes will fit under the standard 15's
- zvh block help
- metering unit
- New RS Turbo G818
- Dash wiring question?
- Turbo active!
- 90 spec interior
- Ohhh Big box....
- break it for spares or fix it??
- Tried to start the car today and... SHE RUNS!!! :D
- might spend 4k on an engine for s1 turbo???
- FTAO Crazy Cage, Rick, or anyone else thats done a hydraulic clutch conversion..
- s2 rear bumpers
- what is the standard compression for a erst s2?
- Coolant pipe from top hose to turbo? Part number
- what do the tuning engineers do when your got you erst set up?
- boost controllers and fuel acumulators
- RS Pick up anyone
- Changing my wheels, opinions on these please...
- headlight adjuster
- Rolling road
- WANTED s2 rs lsd gearbox
- what psi is normal for a standard erst above zero and below?
- Cvh samco radiator top hose
- Is this a chipped ecu
- Diff styles of wheels on a S1
- rs turbo running problem
- s2 body kit
- best way
- got my cabby... couple of niggles..
- torqueing up for cvh head bolts
- Mfi to efi
- Car running on battery...
- Bonnet vents wanted
- flat spot on dyno graph?
- CVH dipstick
- Differences between mfi and efi heads
- G60 ECU??!!
- mk4 bits on mk3...
- fiesta van rs turbo
- i need some advise on getting a second hand chipped ecu
- brake problem...
- what colour hoses would look best?????
- escort rs turbo insurance at 19
- Under Bonnet Decal Help
- engine help
- zetec turbo h/gasket?
- Karlos G or any 1 runnin efi
- S1 / RS Turbo Cold Start
- paint shop nottm/derby
- size of tyres for standard 15" rims
- not boosting prob
- Looking for a mk4 ghia wiring loom
- Seats??
- Oh dear.... do you think it will sell?
- Oil Cooler (modine) Torque setting
- lights and clocks
- Brake disc warping S2 Turbo
- Series 2 Rebuild advice
- rattle
- What size rims for fast road/trackdays are best????
- Help with missfire / oil cap popping off
- efi wiring
- what springs??
- where does this go?
- help help !!!!!!!!!
- short shift
- easiest way to remove a bottom end
- Sunroof removal
- airtec rad new today
- compomotive th2
- A couple of metering unit questions
- Anybody reconditioned a turbo unit?
- D4/matthew m sorted
- turbo
- Head
- Zetec turbo water pump hose /alternator fouling
- XR2i EFi Head on S2 RST
- rebuilt my cvh now it wont start ??
- pace radiators
- 3" bore mongoose
- Bodyshop needed.
- someone bumped my rst and i need help!!!! measurements
- please help s2 running problem
- Welding needed for coilovers?
- Am I missing something.....
- need help!
- Rs turbo mechanic near glasgow
- how much for a turbo rebuild
- zetec turbo water hoses
- need a new cam
- Piston ring removal guide for all you DIYers
- Head Unit with motorised screen?
- running in a new cam?
- Cooling System Capacity
- cossie managed S1 not starting
- fitting cosworth 4x4 brakes
- starting when hot?
- Grs header tank
- Best starter motor for a series 2 rst
- engine oil
- none starter
- My new black s2
- RST S2
- S2 RST running problem
- Mk4 escort spoilers
- Rear Quarter Panel
- For those interested in MFI vs EFI back to back rolling road results!
- s2 smoking
- Anyone know where i can get a knock sesor?
- new clutch
- Wheel bearings
- s2 ride height
- rear brake abs
- Engine build, what bearings would you use? thoughts on ARP bolts too
- uprated hp oil pump 250-60hp
- clutch problem
- running in rebuilt bottom end
- relays under dash
- How much are you lowered running 17's?
- ford clutch
- Quick one Flywheels
- what chip?
- CVH Sumps AND Fiesta RS CPS
- Monroe shocks!!!
- Are EFI CPS's really long??
- Metering head broke?
- No indicators or high beam help!!
- EFI Inlet manifold to oil cooler water hose
- mondeo mk3 brake conversion
- s1 / s2 blocks
- weather strips and roof replacement help
- car keeps cutting out
- efi engine whats needed for cossy management
- Escort RS Turbo owners help needed
- whats next...
- S2 braided brake hoses
- Bumper inserts where from
- megasquirters needed!
- management ??!
- ms1 map help
