I've ran one for a few years now with no issue. Some will say the standard copper cored rad is better for cooling due to the material it's made of dissipating heat better......but i never found this and after having a new copper rad and swapping to the alloy one i personally found the alloy one to keep my temps lower on track (which is what i was having problems with), on the road you should never really have any temp issues if everything's clean/fluched and working correctly.
correct in a way,the alloy one will take longer to get hot but once its hot it cant get rid of the heat as quickly as a copper one,your cars are made to run at a certain temp for a reason.so in effect your raggin your car when the water temp is not at its optimum
Lol, i was fully expecting a reply along those lines (hence why i had already explained why a copper rad Should be better)......they are just MY findings and whilst i can't fault your logic they are what i've found through practical experience so i can't agree with you on the subject. Unless you think temps over 100 degrees are neccesary for an rst to run at its optimum?
From what i can gather you're saying the alloy rad will take longer to warm up (fair point) but why you think i rag my car when it's not up to temp i don't know so i won't be raggin it when the water is not at its optimum.....and you then go on to say it won't get rid of the heat like a copper radiator, which again I have not found to be the case.
what they like for cooling? anybetter then std one? its for my frst,
cheers andy
You will be fine using an Alloy radiator. Although copper is a better heat conductor, Alloy radiators work better as they can be made lighter so do not suffer from heat soak.
