S2 Bumper trim
S2 Bumper trim
Apologies if this has been asked before.
Looking for new black trim for front and rear bumpers for S2.
Was recommended Edgware motor rubber and trim, Ford H9020 trim, 12mm wide.
Purchased a roll of this and it is way smaller than original.
Any idea if a better option is available?
you can reuse the original ones off the bumpers if they came off in one piece ,get a scotch brite wheel for you drill, and this will take all the sticky off the back then put some new double sided tape on and re apply,if yours are damaged i found the cheapest way of doing it buy a rear bumper from the breakers with the trim in it and remove the trim with some heat then use on yours
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
