clutch problem
ive had a problem with the clutch on my rs over the last few day's, ratchet started clicking a while ago, but the last few day's its been getting stiff changing gear and has got worse,(had to double clutch it last night), so its outside and i cant get a gear, there's plenty of pressure in the pedal when pressed, could it be the ratchet and pawl? stuck another cable on it and it was still the same
cheers, neil
cheers, neil
Bodger of Blackburn
i'd change the rachet and pawl for a manual adjustable one off a mk5 (?), then try it again.
in all honesty i'd be checking clutch for damage to pressure plate mor ethan owt, but the rachet and pawl will need replacing anyhow, just seems a result of something else knackered.
still got abs but im used to doing it now
the clutch i have is brand new and came with the car, there is no make's stamp on it so not sure on make and its brown, ive only ever seen black clutch plates, any ideas?
![](http://i199.photobucket.com/albums/aa71/neil73/P020310_1712.jpg)
