RS turbo green relay?
What is the green relay and the pink ones for under the dash, i think the pink is fuel pump relay but what is the green for?
cheers adam
cheers adam
Pink is your Fuel Pump relay.
Green is ABS (I think)
Anyway some of these numbers may match up with the relay you have under the dashboard - just match the numbers on the green relay.
ABS relay, numbers 1,2,3,4,5
Fuel injection relay (pink) numbers 1,15,30,31,87
Heated rear screen relay numbers 5,15,30,31,87
Heated front screen relay numbers 5,30,31,61,87
Low beam headlight (left hand) relay (white) numbers 85,86,87,30
Low beam headlight (right hand) relay (white) numbers 85,86,87,30
High beam headlight (left hand) relay (yellow) numbers 85,86,87,30
High beam headlight (right hand) relay (yellow) numbers 85,86,87,30
Ignition relay
Hazard warning light relay
KE relay (brown in fuse box) no numbers on it
Intermittent wiper relay numbers 85,86,87,30
Ignition relay
JK12
33
26-04-2021 12:09 PM
