efi engine whats needed for cossy management
my car ERST is in bits getting restored and i came across a efi engine last nite and was thinking of putting this in my escort whats needed to put cossy mangement onto it if i have head block and everything for the inlet side
cheeRS chrisy
cheeRS chrisy
Most important two things are the crankshaft sensor and pulley and the dizzy.
Without those the cossy management will not work.
This will probably mean some mechanical changes.
You can just as well use another pulley and connect an aftermarket ecu.
you don't need a cossy dizzy for it, you just use oddkidds phase set up, you don't even need an efi engine although the efi head saves the need for the adapter plate, I'm currently converting my cabrio to the system, have a look on
www.oddkiddcreations.co.uk
Stu @ M Developments
41
21-08-2015 06:47 AM
