- steel rods??
- breather
- Group A coil???????
- throttle cable????????
- my last problem (for now)
- Alloy radiator
- just took engine out
- WHAT POLY BUSHES ARE BEST????
- efi loom wiring diagram
- roller bearing and stage 2 for 500 quid..???
- s1 back strutts
- 300bhp 4WD Cossie Series 1
- Lazy Tappet
- congealed oil
- Price List - Engine Rebuild etc.
- valuation of G19 RST
- zetec conversion
- Diffrence between the RS1600i/S1 ARB
- zvh powerstearing
- poly bushing TCA's
- looking for member darthcrab info plz
- speedo cable
- where to buy silicone hoses from??
- Brake fluid Dot 5.1
- help please s1 replica
- 6 bar of fuel pressure???
- Efi cams on Mfi
- engine prob' ... again
- my ERST is dead again
- s1 rivited arches
- OPPS (ENGINE NUMBER 2 DEAD)
- beige injectors
- s1 turbo rear antiroll bar
- can anyone help?
- loom for efi conversion
- I think i may have just blown my head gasket...
- what off set do i need
- shiney stuff
- chrome bumper trims
- skimmed zetec pistons
- knocking on a fresh engine
- after the rebuild...... strange?
- efi technical q
- dust caps theft
- Would. . .
- took my dump valve off
- Rev counter problem on efi conversion
- s2 zvh mfi - megasquirt
- S1 and S2 TCA's, are they the same?
- Is this a S1 Turbo radiator?
- Problems with hot engine
- fuel pressure regulator...
- lifters/tappets
- twin 044 fuel pumps...
- knocking noise
- ANYBODY KNOW THIS S2.....F406 XEA ?????
- did they make a cavalalire turbo
- bias brakes
- Symptom of bad engine tem sensor
- EFi
- S1 Rolling Road
- s1 front roll bar bushes
- please look in post block pics, wot is it!?? the second pic
- starting problem ...
- Is it possible to remove the cooler of oil?
- s1 turbo loose wire/pipe?
- Cam Sensors for an EFi RST?
- help cant get in boot!!
- if u
- Black front lip
- clutch adjustment
- I Need a OFAB 195 Chip!
- Any point
- any s2 pics
- Oil breather
- Can someone list the differences between 88 + 90 spec
- strut brace
- S2 Engine rattle????
- Using a standard S2 as a daily?
- Boost hose size
- FAO s1 restorers/rebuilders
- GOT IT RUNNING AT LAST
- S 2 tailgate
- wiring problems
- Gearbox oil
- engine run fine when cold but not when its warm
- GearBox Issues???
- cvh water pump...
- Fixed the S1..
- D526 CRK
- dip stick pipe
- speed idle
- A mess about with my recaros hmmm
- rear disc conversion
- lsd gearbox
- boost
- Stack rev counter
- if i set to 10psi do i need a setup?
- Help on ETB
- Increasing boost-need to increase fuel pressure?
- R.I.P Dizzy
- GOTECH MANAGEMENT anybody got this? any good?
- Breaking a s2
- Is a S1 cooling fan the same as an S2?
- My S1 problem.STILL!!!!!!!
- manifold
- RS Turbo Collector's Magazine
- t3 stage 2; actuator -34; no amal valve and only 6psi
- fuel prob
- EFI XR3I WHAT PARTS CAN I USE FOR EFI TURBO CONV
- 2.1 Zetec16v Turbo Alternator
- another tubular manifold question
- Oil in my boost hose!
- hi i have a s1 need finshing what is it worth
- S1 archs on S2
- GRP A Coil??
- metering head removal..stuck
- tyres
- s1 or rs1600i
- amal valve ticking
- does ERST have fuel pressure screw?
- CHATTER !!!!!!!
- WILL HI SPEC 300MM S2 BRAKE SET UP FIT A S1
- Running in a new engine, need guidance
- Clocks for S2
- Stolen Red S2 - F838 DEC
- Rear wheel bearings
- saph cos sender
- H reg S1
- help! im buying a esrt
- spark plugs
- The rust topic
- wat turbo do i need
- how to get 250bhp out of a efi car
- ST brakes on s2 rst
- grey s2 aldershot SPOTTED
- dump valves
- s2 rs holding back
- gasket thickness ?
- Fun in the snow....
- black/yellow wire going to s1 fuel pump relay.
- Decals on rs turbo boot lids
- ECU and tuning advice
- FAO Turboboss
- car won't idle...
- lets have a natter about looms
- my car runs for 3 seconds then cuts out...........
- side skits
- Roof Skin
- cossie managemant parts needed
- Fiesta fuel rail
- OMG
- Again problem with starting
- Big Intercooler Fan Positioning
- im just about to fit my new dizzy.....
- starting problem :(
- which is the best oil breather/seperator to buy???
- Jamsport downpipe
- pistons to 1.8l zetec(zvh)
- would any one recomend engine change to a 1.9
- cosworth management
- fao ecu gurus..rick or safechav...help!!!
- A little help
- What's Unusual about this pic?
- Turbo Zetec in a mk3
- 250-300 bhp how?
- where do people mount oil coolers???
- Efi Questions:
- EFI question
- ahhhhh heater matrix blown today
- Recon engine
- shaking at 60
- breaking or new engine?????????
- series1 using loads of oil?
- MFi to EFi
- chipped ecu question
- insurnace
- how much for a turbo rebuild...??
- EFI and mfi distributor?
- rs bodykit on a cab
- How do you remove the Ignition barrel? (lock set)
- Rear strut brace
- foa christain
- Conversion of Cvh/Zetec using a Rover Inlet???
- cam belt tensioner....
- Rs Turbo Paint Code?
- Does the Mfi head...
- 2wd or 4x4 Cosorth Calipers???
- Zetec Turbo Clutch Options...
- help me b4 i pull my hair out
- 1.8 16v zetec turbo-question time!
- GROUP A COIL
- What Turbo goes on the Series 1?
- Who owns?
- head tested/skimmed
- FAO Stuart Collins.....
- How much does a standard turbo weigh?
- non starting
- braided hoses
- ZVH revvs
- tapping noise after bin driven on boost
- Efi Fuel filter
- Whats the best ERST Colour?
- S1 Engine build/recon + power upgrade£££???? and who?
- Need info on S2
- Vems in Escort Rs Turbo.
- slow series 1....HELP!
- Turbo Elbow Bolts
- has any one got pic of alloy intercooler fitted to car
- Turbo > Exhaust Downpipe seal
- should i fit bumper overriders to my s1
- leaking petrol from cold start valve
- External wastegate
- Straight pipe from turbo to backbox
- from what year escort is my dizzy? and is this the same one?
- indicators
- alright or shite?
- deflex - where to put this 2?
- exhaust mount removal
- charge cooler vs intercooler...
- S1 warning lights
- Fooked alternator ?
- Removing Exhaust Manifold
- EFI cps conversion off the seirra 1.8
- s2 Alternator belt
- pin 20 on the ignition ecu...............
- no power or power only at 18 deg
- torque setting, water pump
- Restoration Garage!
- MAF sensor?
- gearbox question
- MDF Boot build or Strip and Paint?
- any roll cage - were to buy?
- wheel allignment
- Greenlight Insurance-Up t0 Stage 1 conversion free of charge
- --£7000 Insurance pay out for Escort RS Turbo--
- boost problems! help?!
- ZETEC RODS
- both sides of my coil are +ve, is this right?
- 16" compomotive mo's
- s1 on cosworth wheels
- parts old and new?
- help with suspension
- ignition timing
- revs cut out to soon?
- im not getting any fuel past the metering unit -------HELP
- escort getting to hot
- How many boxes does an original RS Turbo exhaust have?
- willl a blue red blue ecu work in a 90 spec car?
- 90 spec spot lights
