EFi
Old Feb 16, 2007 | 02:55 PM
3i_gaz's Avatar
3i_gaz
Default EFi
i have a mk3 escort going to be turbo'd, the engine i have is MFi but i want to run Efi for reliabilty, better cold starting and i want to run around 250 horse
right i know its probabley been discussed a million times before on this board, but i'm still not 100% clear on what i need and what are the best bits to use.
so really, what management is best? will i benefit much from aftermarket management, if so what do you recommend? car will be running pretty much stage 3
do i use a fiesta turbo flywheel and get the crank pickup from there?
do i need to ge a cam sensor bracket made up and what cam sensor do i need?
i have a fiesta turbo head there with full EFI inlet and a fiesta turbo loom. what else will i need
and also if i need a custom loom making who is the best person for the job?
thanks for the help chaps.
Old Feb 16, 2007 | 03:55 PM
grsford's Avatar
grsford
imo if your after 250+ bhp fiesta ofab/ofac managment would not be the way for you to go due to it needing a custom map/chip made up which can be expensive, go aftermarket
Old Feb 16, 2007 | 05:32 PM
3i_gaz's Avatar
3i_gaz
what management have people found the best to use with a CVH?
Old Feb 16, 2007 | 06:35 PM
grsford's Avatar
grsford
it all depends what you want for the managment and how much you have to spend?
Old Feb 16, 2007 | 06:38 PM
Mixja's Avatar
Mixja
420
im on a tight budget so im going cossie... if money were no object tho, id be goin omex or autronic...
Old Feb 16, 2007 | 06:44 PM
nigel b's Avatar
nigel b
autronic works well
find a local mapper/someone you trust to map the car and then decide on the management
Old Feb 17, 2007 | 05:13 PM
3i_gaz's Avatar
3i_gaz
Originally Posted by nigel b
autronic works well
i think the only person i would let map my car would be MSD or that ahmed bahjoo guy.
how much is this omex or autronic management?
sorry to seem really blunt and stupid but i've never looked into EFi before in all honesty.
Old Feb 17, 2007 | 05:15 PM
nigel b's Avatar
nigel b
if you want to use stu or ahmed found out what they prefer to map
omex/autronic is probably Ł1500 upwards
Old Feb 17, 2007 | 05:39 PM
3i_gaz's Avatar
3i_gaz
yeah i will find out, cheers mate
what crank sensor do i use then? and what about a cam sensor? cheers
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
