bias brakes
bias brakes
any body on here done a bias brake conversion to there escort with the pedal box etc as i think i might do that aswell while the engine is out & to get the best from the rear disc conversion that will be put on also, pics or links would be an advantage
Originally Posted by gus
i do also
no pics as yet thou as its all gotta be refitted yet
mine is with internally mounted master cylinders, both cliffs and tony's are mounted inside the engine bay (probably easier)
this is mine....
got it from rally design, think it was def well under 200 sheets
mine needs the steering coloum modifying thou, not a problem on mine thou as i have a weld in cage to come off of
gartrac use to make them for thier rwd conversions, could try them
or
hassle martin at mef motorsport, he has had loads of interest in them already
or
They have a reservoirs per master cylinder. And pedal boxes usually have 2 different sized cylinders to help balance the braking front to rear
this is mine....
mine needs the steering column modifying thou, not a problem on mine thou as i have a weld in cage to come off of
or
or
1 cylinder for front brakes, 1 cylinder for rear brakes.
Diffrent sizes to compensate and help out the brake bias (rear brakes need less pressure)
Ignore the 'bolt' through the bias adjuster this was a work in progress shot about 5 years ago But it shows you the frame work we made for mine.
How it looks with the bottles
We made one the other week for a RWD Mk4 - I guess that could be converted over to FWD applications - if enough interest Everytime we ask we only ever get about 2 - 3 people interested.
We make all sorts
The direct fit Subaru one...
The Sierra one...
We make all sorts
The Sierra one...
this is mine....
or
or
where mine has internal master cylinders they foul the coloum
