dip stick pipe
Old 13-02-2007, 02:02 PM
jimmylaud
jimmylaud's Avatar
Default dip stick pipe
my s2 has been loseing a bit oil now for a bit been trying to find out from where but today ive noticed the dip stick pipe had come out of the block it has been slack for a while tho do you think its just worked its way out with the vibration and hence causing me to use oil or do you think it could be back presure causing it
Old 13-02-2007, 03:56 PM
Dragsteer
Dragsteer's Avatar
does oil smells on petrol?
Old 13-02-2007, 04:40 PM
Brian
Brian's Avatar
Mine is leaking from the dip stick tube aswell the dip stick tube is lose in the block on our's got a new sitting here just got to fit it
Brian
Old 13-02-2007, 04:44 PM
zippyobrien
zippyobrien's Avatar
mines the same, dontno how to go about fitting new one though, do you just shove it in?
Old 13-02-2007, 06:15 PM
jimmylaud
jimmylaud's Avatar
oil does have a very slight smell of petrol is that bad ? so do i just have to get a new one
Old 13-02-2007, 09:08 PM
Dragsteer
Dragsteer's Avatar
maybe worn piston rings? or maybe rich mixure and bore wash.
if engine consumes much oil it is maybe worn piston rings but then you will have smoking signals
Old 13-02-2007, 11:27 PM
jimmylaud
jimmylaud's Avatar
no smoke when driving or giving the car a hard time and the dip stick pipe was right out of the block the engine is still quite a fresh rebuild only done 12k so i think its just to do with the pipe i hope anyway ?
Old 14-02-2007, 08:00 AM
SaqsS2turbo
SaqsS2turbo's Avatar
it just pushes in twisting left to right myn just came in my hand wen the engine was out so got a another was bit stiffer and pushed it in no leaks some times wears so gose loose turns all over the place
Old 14-02-2007, 09:58 AM
jimmylaud
jimmylaud's Avatar
perfect thanks for the help
Old 14-02-2007, 07:02 PM
SafeChav
SafeChav's Avatar
Im surprised you havent noticed the engine running a bit lumpy
As said though they are interference fit
Old 14-02-2007, 08:04 PM
StephenC
..BS Motorsport..
StephenC's Avatar
I need a new one then. Been loose for ages
Old 14-02-2007, 08:55 PM
EssexMikeSi
EssexMikeSi's Avatar
mines quite lose to. where it joins the block i noticed a load of what is like putty round there where previous owner has tired sticking it back in i think
Old 15-02-2007, 09:39 AM
jimmylaud
jimmylaud's Avatar
i have noticed the engine running lumpy but the car has not been getting driven alot been ordering alot of parts all getting fitted next week so it should be happy days i hope so once the pipe is back in that should stop the car running lumpy ?
Old 15-02-2007, 09:42 AM
SaqsS2turbo
yup yup as its looseing preasure through the dipstick hole
Old 15-02-2007, 09:45 AM
jimmylaud
jimmylaud's Avatar
cheers for the help guys
Old 15-02-2007, 09:46 AM
SaqsS2turbo
Old 15-02-2007, 02:09 PM
SafeChav
SafeChav's Avatar
Wrong!
Its an air leak, not losing pressure (crankcase pressure is bad)
Old 15-02-2007, 04:40 PM
Moonie
Moonie's Avatar
A bit of strong (green) thread lock on the tube before you fit it will prevent it leaking and stop it coming out again.
Old 15-02-2007, 04:44 PM
SafeChav
SafeChav's Avatar
And what about the next time you want to remove it
Old 17-02-2007, 07:21 PM
Moonie
Moonie's Avatar
Sump off and knock upwards with a soft face hammer
Old 17-02-2007, 09:09 PM
Andy_R
Andy_R's Avatar
Ive seen this type of problem loads on modified RST's, fitment of a decent beather system has often cured the problem.
Old 17-02-2007, 10:02 PM
gee1599
gee1599's Avatar
a new tube will normaly fix your problem
Old 18-02-2007, 01:23 PM
gaz s1
gaz s1's Avatar
anyone know if ford still do the tube for the s1 as its shorter than the s2 and mines loose as fuck
Old 18-02-2007, 01:28 PM
zippyobrien
if you have a baailys breather system them it wont run lump as it will no longer be an air leak as the bailys system breaths to atmos no the metering head, like wise with efi converted cars, mine looks like some ones used clear silon and gunned it in
doesnt make the cr lump though, and not loosing oil form it,
can you still buy new pipes?
boeb
09-01-2020 05:11 AM
07-10-2015 12:56 PM
stephenb4506
33
02-10-2015 06:25 PM
SMILER258
28-09-2015 09:04 AM
mpilk
27-09-2015 09:21 AM
Quick Reply: dip stick pipe
