speedo cable
focus rs 1672
speedo cable
tracked my none working speedo down to the cable broke at gearbox end,about 2 inches from join to box
now this is the 2 part cable,could i basically take the join that extends the cable for abs off and the rest should just fit to gearbox<will it be long enough?is the non abs cable just this one and you buy the extension for abs
gonna go out and try it anyway just makin sure before i waste my time
focus rs 1672
i understood that the 2 piece was an extension to get round abs,save ford makin another cable,as whenever ive had any replaced theyll always asked me if its abs or non abs,yesterday i went to masterparts to get a cable and the guy says that the dont do them but the extension was only for abs models,so i assumed because i dont have abs then the extension(which is the bit thats broke) can get takin off and it will still fit
focus rs 1672
Originally Posted by davidnormanuk
Mine comes apart in the middle of the cable why's that then?
Its got a section that can be unscrewed so the cable can be split into 2 halfs. I'll get a pic of it and post it up.
focus rs 1672
the big section i presume is just the std cable and you buy the extension to add to it to extend round the abs
focus rs 1672
Originally Posted by SafeChav
Thing is though, the 2 piece cables have that big ass nut thing half way down, a standard cable doesnt have that on the instrument end
basically its the same ends all the extension do is make it longer,thats why i think it should do the job,ill find out tomorrow for sure(weather permitting)
Yeah but ive seen the cable you are on about, and the join is always by the wiper motor, leaving the piece with the correct ends way too short to be a normal cable
focus rs 1672
now you mention that youve seen it beside the wiper, its ringing bells with me too that ive seen some with the join up there,but mine is defo down at gearbox end,sits just behind amal valve when cable is hooked up
muz
30-09-2015 08:29 AM
