s1 back strutts
is there an easy way to get these fuckers off at the top
been trying for a whole 20 mins tonight
& just gave up, any hints or tips
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
You'll need to undo the bottom bolts aswell ideally.
I have had them out before without undoing the bottom bolts but its a right slag to do, undo the bolts it will be quicker in the long run
If you don't have an air impact gun (whatever it's in english...), Try pulling strongly the bottom of the shock to the side while undoing the nut at the top. This way the shaft won't rotate.
Originally Posted by SafeChav
OMG
have you tried taking the nut off the top of the shaft then pmsl
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
JesseT i havent got an air impact gun but i'll try the pullin at the bottom of the shocker...thats the kind of answer im looking for safechav
Your meant to use a 6mm allen key in the centre of the shaft, but ive never had one whenever ive needed one, i find putting the ratchet on the nut and just sharply turning it will free the nut as there is a lot of resistance between the shaft and top mounting bush
well i got them off tonight by simply pulling the bottom of each shocker towards me & they all came off without a problem, a little tip for the future i think cheers JesseT
JK12
33
26-04-2021 12:09 PM
