my last problem (for now)
Old 21-02-2007 | 09:27 AM
Dragsteer's Avatar
Dragsteer
Default my last problem (for now)
I repair most of the problems, but I still have one which makes me mad.
When I go in 3nd gear (for example) and push throttle, car going ok, but when boost reach 0.5 bar (standard max boost) engine start making noise.
and I have feeling that car going better on low boost.
Is possible that air going out on exhaust mainfold, on higher boost ?
see picture? What you thing, is possible thata air going out??
Old 21-02-2007 | 09:40 AM
SaqsS2turbo's Avatar
SaqsS2turbo
your manifolds cracked in 3 places
Old 21-02-2007 | 06:33 PM
Dragsteer's Avatar
Dragsteer
yes maybe because I dont have flexy exh pipe and ex owner has touch the ground few times. Is possible that exh mainfold leak air out on boost/high temp?
Old 21-02-2007 | 07:56 PM
MikeyXR2i's Avatar
MikeyXR2i
Change the manifold, when it heats up those cracks expand, and air gets sucked in giving poor performance.
Old 21-02-2007 | 08:38 PM
fezzajsy's Avatar
fezzajsy
m8 u need to sortt that manifold quick...
Old 21-02-2007 | 09:38 PM
Dragsteer's Avatar
Dragsteer
I have spare one BUT , problem is to put ex mainf off the car!
Is this recommended to give the to garage to take this out and outt new one?
I think problem is because rust eat screws and they can easy brake isnt ?
Old 21-02-2007 | 10:23 PM
zippyobrien's Avatar
zippyobrien
not to hard,
lots of wd40 (penatrationg oil, ) and a blow tourch,
or you could use a bolt cracker if there really bad,
should only take a few hours
Old 22-02-2007 | 09:23 AM
Dragsteer's Avatar
Dragsteer
thanks on advice mate!
DAZZER
30-09-2015 08:43 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
Quick Reply: my last problem (for now)
