How do you remove the Ignition barrel? (lock set)
Called down to my local scrappy saturday and found a really solid mk3 bonus, robbed of all i could on the day. Thing is i've got the tailgate off it with the keys, but want to get the full lock set out, how do you remove the ignition key barrel. I've been told you just turn it to first position and then with a small screwdriver just push up a retaing clip and it just slides out... is that right??? i wanna call down on my work break and get the rest if poss + whatever else i can salvage. Cheers
on the s1/mk3 there is a little grub screw at the back of the ignition assembly, facing backwards, u gotta cut a little groove in it n undo it, the whole lot will slide off then... on an s2/mk4, it just taps off with a hammer, i think....
JoeyBoyden
04-01-2024 02:36 PM
CabrioTurbo
01-08-2015 11:04 AM
