PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. turning boost up
  2. Wot Box???
  3. Extra Fuelling ??? Aeroquip?????
  4. help needed ERST boys please?
  5. complete EFI conversion parts list ???
  6. rattling noise on boost?
  7. stalling prob help plz
  8. WANTED Roll Cage
  9. anyone got a s2 anti roll bar for sale in leicester airea?
  10. wiring in cooling fans on switch
  11. mondeo brake servo and master cilinder in escort mk4...
  12. Poppin out of 5th...
  13. anyone got a s1 fuel relay they waana sell
  14. S1 Electrical problems
  15. sump help please guys : )
  16. Help - Brake problem!!
  17. no boost?
  18. Gearbox problems ( i think ) Part 2 with pics
  19. rs turbo bits
  20. Aeroquip brake lines
  21. Raid steering wheels..
  22. Fitting OMP Seats
  23. AP Racing clutch plate ~ CP5351-16 ~ What power
  24. series 2 sparco strut brace
  25. boost problems, please help
  26. front footwell speaker size
  27. dipped headlamps and fog lights and mirrors
  28. Series 1 Dashes
  29. s2 guru
  30. radiator top hose
  31. gettin frustrated!
  32. aerial-advice needed
  33. R/R @ Well lane turbo
  34. Braking Problem
  35. Clonking noise as i pull away
  36. Mudflaps for a S2
  37. Newbie with questions
  38. fao people with cossie management
  39. CUSTOM DASH WORK [ PICCY ]
  40. fuelling a 1.8 zvh ??
  41. My new car
  42. exhaust gasket
  43. Standard S1 Exhaust
  44. fookin car
  45. My S2.....
  46. fitting & setting up of MEF adj TCAs
  47. MOT Failure
  48. Squeeky clutch pedal
  49. S2 erst engine and loom?????????
  50. HELP NEEDED ON LOW COMP PISTONS
  51. boost dropping **fixed**
  52. 1600CVH, what oil??
  53. steel wheels for series 1
  54. Anyone got any springs
  55. Engine bay transfered!!!!
  56. What oil pressure should a RS Turbo run at???
  57. Rear suspention adjusment on a s2
  58. Ford motorcraft clutch
  59. fuel tank
  60. another electrical problem-now sorted
  61. S1 seats
  62. garage's for rs work in preston area?
  63. New wheels trial fitted
  64. my s2 erst
  65. stage 5 head
  66. what to do
  67. cleaning stainless steel
  68. How to get Inlet manifold looking like new ??
  69. Donny North RST`s
  70. fuel lines
  71. ESCORT REAR HANDBRAKE CABLE GVC2290
  72. its a turbo...
  73. busy weekend painting!
  74. abs light
  75. clutch ratchet fcuked
  76. erst engine parts needed
  77. My arese end
  78. roll cage cost ??
  79. Removing Rusty Sunroof Screw
  80. s2 abs
  81. Cossie management....
  82. HELP, done compression test - now it wont start
  83. breaking my escort soon
  84. need a idiots guide for frst management on erst
  85. What offset for an s1
  86. cooling problems
  87. buying s2-what to look for
  88. can anyone I.D this
  89. FTAO Mr SafeCHAV!
  90. Fuel pump cradle
  91. Series one grille
  92. NOOOOOOOOO, ive killed it....opps!
  93. Escort front hubs are they different mk3 and mk4
  94. Anyone know who SamERST is?
  95. Would scare a few Scoobys!
  96. erst s2 abs warning light problem
  97. My S1 (NOT 56k friendly)
  98. Series 1 RS turbo Cabby-PICS!!
  99. whos been modding this weekend?
  100. Radtec intercooler, what fan??
  101. Garages for RS Work
  102. comp brakes
  103. ? anyone
  104. Fitting cossie brakes.....
  105. what a buy!!
  106. spottered Tony turbo
  107. clutch pedal conversion
  108. no dipped beam
  109. who was it????
  110. My engine bay pics - more pics added
  111. hood
  112. S1 Easter Bargain!!
  113. Another chav mobile
  114. whats best to re-seal seams/joints?
  115. wheres the arial
  116. Lookie here
  117. Car Show S1 Photo Help Required
  118. Pics of s1s with 17inch rs7s
  119. brake servo ?
  120. megasquirt
  121. cossie 803 injectors
  122. CVH flow testing
  123. what mods do you have and what power are you pushing?
  124. suspension
  125. starting when warm problems
  126. Steering coloumn bush kit
  127. tuning the 1.6 cvh
  128. Best cam for RS Turbo?
  129. Come on own up
  130. First scalp since rebuild - Scoobie WRX Sti
  131. What.....the.....fook
  132. stage 1 turbo boost
  133. abs and mots
  134. how restrictive are rs turbo heads?
  135. URGENT REPLY NEEDED**********
  136. what power is a standard crank good for?
  137. Car stinks the garage out - Petrol fumes!
  138. CANDY S1 PROJECT * UPDATED*
  139. how do u permanently repair s2 roof
  140. Probably all seen it but...
  141. play in quick rack...
  142. cold start running problems ERST
  143. replacing chassis rails...sum1's gotta know wot todo
  144. general servicing
  145. Coil overs
  146. magnex flexi bracket 2 chassis leg
  147. Fuel Pump Relay
  148. Track Day ~ Cooling systems
  149. HELP I NEED SUMIN TO BEAT A FERRARI 355 SPIDER....
  150. Rear crank oil seal carrier
  151. f360 kbm
  152. Non starter - advice please
  153. T34 turbo
  154. rip speed
  155. what size are these rear suspension nuts & bolts?
  156. S1 Engine/gearbox mounts, where do i get them from?
  157. help needed
  158. Scorpion Backbox on Magnex system?
  159. twin plate paddle
  160. HELP
  161. Custom Aeroquip fuel line
  162. overly loud tapping
  163. What turbo for 2.1 ZVH?
  164. ENGINE???? please read
  165. vin number
  166. Favour needed please!
  167. Details on f66neb
  168. how much oil should ?
  169. Intercooler
  170. Big filter
  171. S1 stereo fit
  172. s2 for cossie
  173. HELP NEED ON PICKING A CHIP?????
  174. Can You Still Get Opening Rear Quater Bolts for S1?
  175. Just got my S1 back from the bodyshop!
  176. irratic ideling on rst
  177. pedal box kits
  178. Will an S2 head go onto my S1 engine?
  179. Blitz power meter settings
  180. Engine goes back in the car
  181. Car won't start........is it a relay??????
  182. zetec conversion?
  183. oil level
  184. alternator and bracket on s1 fitting? pic maybe?...thanks
  185. Cossie cooler pics
  186. How do i fix the fan switch??
  187. why is it boosting 1.5bar help
  188. NEW TAILGATE
  189. brake grinding
  190. fitting efi
  191. princess diana series 1
  192. crank grind needed in norfolk area
  193. SUSPENSION & WHEELS ADVICE
  194. Zetec Compression Ratio
  195. Dump Valve
  196. what cossie front brakes have some of u got on ya s2
  197. Really Bad Steering Coloumn
  198. Urgent Advice Needed
  199. REMOVING RADIATOR???????
  200. efi inlet
  201. going to look at a series 1
  202. s2 buying advice
  203. 3i to rs turbo wiring loom
  204. xr3i to rs turbo conversion
  205. Building the engine.
  206. shuddering under heavy braking
  207. rear disk conversion
  208. Painting your block
  209. Zetec turbo
  210. You'll all love this prime example of an S2
  211. perspex windows
  212. metering head problem ??
  213. reconnecting clutch cable @ gearbox end
  214. PRO ALLOY OR GRS
  215. FITTING SIERRA COSWORTH SEATS
  216. best place for a 1900 cvh
  217. oil change s2
  218. dump valve
  219. SPOILER ISSUES
  220. Chassis rails
  221. Shortshifters
  222. new back panel????
  223. WANTED rear interior panel
  224. who's s2 is this again?
  225. BREAK OR SELL?????????
  226. 2 STAGE BOOST WIRING???????
  227. amal valve from ford
  228. cossie management
  229. cambelt ( stupid but vital)
  230. window removing
  231. Best flow
  232. Gearbox
  233. amal valve wiring
  234. Main bulk head gromit split - fixes?
  235. money grabbing car!!!!
  236. ERST sunroofs...
  237. Turbo Cooling, Series 1's and 2's
  238. Series 1 towing eye/bracket
  239. Hybrid?
  240. s1 b830 ykj
  241. WHICH PEDALS
  242. who does good prices on AP 4 paddles?
  243. BARGAIN . . .
  244. Help with Part number!!!
  245. Brake bias valves
  246. Engine bay wire clips
  247. i hate turbos
  248. Problem Dumping (Dump valve, not shitting)
  249. brake disks
  250. piston to bore clearence? on zetec engine?
