tuning the 1.6 cvh
tuning the 1.6 cvh
whats the order to tune the CVH
what should i do next?
so far standard engine
GRS
PACE RAD
BAYJOO 195 chip
MAGNEX
K&N Panel filter
16psi
196bhp @ fly
what do i do next then?
is it time for a low comp bottom end?
IANS2RST has one for sale in the for sale section
what do you need to know about bottom ends to buy one
GRS
PACE RAD
BAYJOO 195 chip
MAGNEX
K&N Panel filter
16psi
196bhp @ fly
A low comp bottom end doesn't have to be a steel one mate, that's just where the rods used are steel. Steel rods and forged pistons would give u a solid bottom end tho, to enable u to run more boost safely, as u wouldn't wanna run much more than 20p.s.i on standard rods. Not a cheap option tho, rods will set u back around the Ł700 mark, pistons Ł500. Couple this with ARP bolts, machining, new bearings etc and u won't have much change from 2k for the bottom end!
Custom
all steel bottom end is steel rods and crank
i would go for a good ported head and possibly a cam can give upto 50 bhp to as you cant really use more boost with your standard turbo
Originally Posted by Oranoco
A new cam and the Kent CVH35 is my choice
Do you use a CVH35 for 250bhp Steve?
personaly prefur the piper cams, have a look at the gains there are plenty of print outs available, piper is a much smoother curve!!!!
there is allways doing the injectors too
Don't ask - I don't know
Re: tuning the 1.6 cvh
GRS
PACE RAD
BAYJOO 195 chip
MAGNEX
K&N Panel filter
16psi
196bhp @ fly
GRS
PACE RAD
BAYJOO 195 chip
MAGNEX
K&N Panel filter
16psi
196bhp @ fly
i would either spend the money on the brakes if not already uprated, or a good suspension upgrade and polybushes.
alll very well haveing a quick car its how it handels and stops that is just as important.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
