S1 Electrical problems
Old Apr 21, 2006 | 06:57 PM
Pates 'E''s Avatar
Pates 'E'
Default S1 Electrical problems
I need some help. My S1 has developed a problem with the electric windows they dont work! I think it maybe associated with the opening and closing of the D/S door possible break in the wire? added to that neither the horn or side lights work. I live in greenford(west london) if any one was able to come down and sort it i would be well pleased.
TA
Andy 07759534667
Old Apr 21, 2006 | 07:30 PM
gup's Avatar
gup
Default fuses
have you checked your fuses yet fella
Old Apr 21, 2006 | 08:23 PM
Moonie's Avatar
Moonie
If the windows start working when the door is moved then it will be a break in a wire where it passes from the body to the door through the rubber protective grommet or near to this area.
As for the horn and sidelights I would start by checking the fuses, if they are ok it mite be worth looking at a wiring diagram to see if the two circuits share anything in common (earth, splice in wiring etc). Is it just the front sidelights that are not working? If so this would eliminate the switch.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
