Fitting cossie brakes.....
Im in the process of building a s2 rst track car and im going to use the brakes off of my sapphire cosworth but the only thing is....
Where can i get the adapter plates from for the caliper to go on the hubs?
Is there a company tht makes them?
Input pls........
Input pls........
if you are using 4wd cossie calipers they bolt on to the original position but you need spacer washers to make the caliper sit on the disk correctly.
using 2wd 4 pot calipers you have to have 3- 4 mm machined off either the hub or the inside of the caliper face.
I've got 2wd calipers n discs on my s1. Had to machine 4mm off the mating face. they don't fit behind the standard wheels but they are awsome!!... a good excuse to get some nice wheels too
Ask me a question!
Re: Fitting cossie brakes.....
Input pls........
Input pls........
If you have a 4x4 as said above the Calipers will be a direct fit with a pair of washers made for the offset. You will need to use 2wd disks tho.
The back is just as simple but you will need to fit a pair of Stainless Steel brackets for the carrier to bolt to. They cost £35
HTH
Regards
Jano
Originally Posted by Jano_OddKidd
There are reasons the calipers sit like that.
But yes i do have brackets which hold the caliper at 3o'clock when looking at the hub.
What are the reasons if you dont mind me asking
09-10-2015 07:38 PM
kosienutter
31
22-08-2015 09:55 AM
Red_bull
09-08-2015 08:34 AM
