amal valve from ford
just phoned ford up for a amel valve as mine has broke they want 48quid for one are there any other solutions to get round it
has anyone got a good picture or diagram of what vacuum pipes should be disconnected/blanked off/had the bleeder put in???
mines got a bleed valve installedand at the moment its setup like this:-
- Bleed valve is connected in a hose between the turbo and the actuator.
- Hose off the metering head is blanked off.
- No hoses from the 2 amal valve ports
- No hose coming off what 'looks' like some sort of fuel pressure regulator.
Is the above all ok? Just wanted to check.
borboyous
22-08-2015 11:17 AM
