Clonking noise as i pull away
Hello chaps.
Got a little problem that when i pull away i get this loud clonking noise (forward or reverse)
I've replaced the outer CV joints (for brand new ones).
The inner joints are the tripod type (but are old).
Could the problem be the inner joints? and can i put a standard joint on to the shaft?
Or is it likely to be an engine mount or something?
Any advise would be great to give me a bit of a fighting chance when i start to look for the problem at the weekend.
Matt
Matt
Thanks guys.
mounts are all new, but i will defo check these.
TCA are brand new.
Fully polybushed
New wheel bearings
Drive shafts are still a possiblity as the inner joints are not new.
all suspension is new inc poly strut top bushes.
Exhaust, quite possible as it sits very close to the gear linkage.
I put a post in General this morning coz i was having agro with the clutch last night.
Its also possible that the clutch could be causing this clonking. See here --- https://passionford.com/forum/viewto...757863#2757863
TCA are brand new.
Fully polybushed
New wheel bearings
Originally Posted by NUTS RuS
Just because something is new don't rule it out
If you fit a brand new round peg into an oval hole it will still clonk
Originally Posted by safechav
Depends what the peg is doing
Anyone fancy a group buy
I knew i would regret that username seemed like such a good idea at the time
