starting when warm problems
Old Apr 13, 2006 | 06:08 PM
sime73's Avatar
sime73
Default starting when warm problems
ok, next problem ive got.
from cold it starts straight up, only cranks over for a second but the idling is high and rough, it sounds like it misses a few times on tickover and splutters when i try to rev it.
when its been running a for while i'll turn it off, leave it for a few mins then try to start it up. it will fire then just crank without anything
ive disconnected the cold start, checked the auxillary air device, checked for vacuum leaks
when the ignitions on tho, the fuel pump clicks on now and again so could i have a leaking injector?
Old Apr 14, 2006 | 03:21 PM
Rick's Avatar
Rick
how u mean fuel pump clicks? It should prime when u turn the ignition on for a second. It could be too rich, seen this plenty of times. Or, not enough vacume depressing flap - see how much it moves when cranking.
Old Apr 15, 2006 | 12:18 PM
sime73's Avatar
sime73
it primes when i turn the ignition on, then it will intermittently prime again
the flap is ok
just wondering why it keeps priming....i didn't think the ke jetronic sensed a pressure drop ?
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
Zoggon
Aug 10, 2015 10:39 AM
Sjieter
Aug 5, 2015 09:47 PM
