window removing
window removing
how would i remove the windows, rear screen and front without braking them and how would i put them back in again
Front windows - remove door panel, remove screws that hold on motor, remove the strips along the base of the window thens it just a bit of jiggery pokery to get it off the runner aand out the through the top of the door.
Repeat other way around to put back in.
Rear sides- when I took mine out the rubbers were fucked so I just cut them out, but if yours are fine, you need to work it out slowly with a screwdriver and some patience does really depend on how tight the rubber is..
You'll need to string them in and again some patience.
As for the rear and front I havent taken out but there both of rubbered in so I should think its similar to the rears.
