overly loud tapping
i know that cvh's tap anyway but mine seems to tap louder than me dads cab, wey his doenst tap at all
is there any thing a can check with out whippig the head off?
cvh that taps, nothing new there then, get your self down to ure local motor factor and buy a set of lifters, cheap as chips and easy to fit, just take off rocker cover, undo M8 nut on follower, lift off and slide out the lifter, sometimes they stick a bit but is no biggy, then drop in the new one and re fit follower, takes about 2 mins a piece so no more than 30 mins all done!!!
Not sure if this bit is true or not but have been told in the past that you need to squeze out the new lifter before fitting, no idea if thats right as ive never done it but any one who can set that bit straight plz do,
Do an oil change at the same time as the lifters are filled by the motor oil, thats why they tap a bit on start with some cars, takes a min for the oil to get in, so no point in running nice new parts on old oil!!!
And you don't need to squeeze the lifters out they meter oil
ahh good point, forgot to mention that, stick ure finger down the lifter port after removing and check the cam for wear, i see where your comming from with the cam wear problem, ive had alot of lifters go on orions and scorts when i was in my teens, so could be either, just personal experience that it was allways lifters with me, never had to swap out the cam
that said, i wa probably just lucky!!
Believe me the cams on these cars wear from the moment they left from the factory. I guarantee on your cars if you take the lifters out the bottoms are dished, which means cam wear. I also bet they had to be pulled out the lifter bores with grips yeah???
Little_Hoss: when you are trying to pull your lifters out, if they raise about 5mm then go tight, DON'f FORCE THEM!!! That means they are 100% fucked and so is the cam, you will have to take the cam out and pull them out of the side of the head.
Originally Posted by Little_Hoss
the cam has done less than a thousand miles ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Did you do the alleged running in procedure for the cam?
kent cvh 35 including followers and lifters etc
run in and timed up by l and j mcdonald racing (morgan engine builders)
this was done before i bought the car off me mate
Hmmmmmm, strange. Them kent lifters are mena be the bollucks aswell, theyre anti pump lifters.
Before you do anything literally get the rocker cover off and see if you can feel any play in any of the rockers using rule of 9.
Actually thinking about it what am i saying its not there they use a different procedure. Right, basically, turn the engine over by hand, start with valve 1, get the valve fully open, and basically then you can check the rocker for valve 8, then watch the next valve to go fully open, and check the one which makes the number up to 9? Does that make sense?
yeah got that mate
if all that seems normal al put some pictures up and see if theres somthing obvious that i mite b missing
its definatly a hate hate relationship with this car at the minute
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
If no good while you have the cover off whip the rockers off and just see if any of the lifters are tight in the bores, and don't want to come out freely. If any i'd be willing to bet its the lobes for cylinder 4.
Don't let it defeat you, the top ends on CVH engines are shocking
That cab looks pretty sweet aswell mate
liking it a lot
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
me mate is mechanically spot on so al show him this post as it may be gettin past me a bit now
just put a new full s1 interior in the cab last nite but still needs the speaker pods and a new carpet and it will be spot on, i couldnt beleeve how quick and smooth standard rs power is, cant wait for the summer months to use it (even though its me dads car like
pics of the cabby coming up 2nite depending wheter or not me s2 pisses me of
Its not hard mate, have a go, have some faith in yourself.
LOL ive got my front speaker covers sat here staring at me lol
Hard to find MK3 ones that aren't cut
PMSL you can't make the cabby suffer because of the inferior S2
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
yeah we had a chew on getting some
think the s2 mite gan the journey soon
av got a s1 in need of restoration, its getting more and more tempting
to do it!
maybe when me mef bottom arms come ill like the s2 again
to do it!
jonfoc
11-09-2015 04:46 PM
