PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 [107]
  1. doh whats wrong now
  2. How rusty is your RS?
  3. HELP!!!!!!!!!!!!!!!!!!!fuel pump not working
  4. Stoppers.
  5. s1 parts any 1 in scotland help??
  6. Starting problems!
  7. escort s1 for sale
  8. escort s1 for sale
  9. will an uprated s2 intercooler fit a series 1???
  10. Engine probs.
  11. s1 parts
  12. Detailed cossie brake swap for ERST
  13. What clutch for about 1.3 bar
  14. crank shaft oil seal + clutch
  15. rev limiter
  16. S1 Oil change...how???
  17. S1 Engine not well any ideas ?
  18. Time to stop lurking!
  19. enthusiasm boost required!
  20. 90 spec RS TURBO WANTED!!!!!
  21. Repainted S1 Is it worth less?
  22. Knocking from passenger side when accelerating and turning.
  23. series 2 erst hoses
  24. Do u need arch mods for 17's on an ERST?
  25. how expensive are bloody rs'
  26. fitting 2wd & 4wd intercoolers to a ERST
  27. throttle control switch
  28. Whats my S2 worth?
  29. boost holding problems
  30. is worth saving a rsturbo?
  31. FRST & Cossie brakes Question
  32. Is this a possible battery problem ????
  33. turbo options
  34. pic of turbo elbow
  35. which suspension??
  36. Escort RS turbo!
  37. 2 things wrong with my rs turbo, help?
  38. rear disk conversion
  39. Smallest amount of boost on a -34 actuator
  40. Advice please....s1 not starting propperly!
  41. Brake's
  42. just joined!! need help..
  43. Rear Anti-Roll Bar - Series 2
  44. Difference S1 and S2 engine
  45. what tyres??
  46. S2 rst problems, help?
  47. engine rebuild
  48. Help S1 RS Turbo Problems
  49. WHATS MY CAR WORTH????????? (pics)
  50. S/ 2 RS TURBO FUEL
  51. engine flushing at oil change escort rs turbo?
  52. adjusting boost
  53. jus ordered
  54. GRS intercooler do they fit without cutting the bumper ??
  55. S1 Buying Guide
  56. some help plz
  57. Post up your favorite pic of your RST
  58. Info needed please!!!!!!!!!
  59. sh**e handling
  60. looking for help
  61. Brake Bleeding
  62. HELP...pic of metering head with inj. pipes on it request
  63. name that wheel, any ideas (pic)
  64. difference between s1 & s2 standard exhausts
  65. hello everyone!!
  66. My Car 4 Sale...
  67. bit of advice
  68. INTERCOOLERS...
  69. waste gate chatter
  70. MY RS WAS STOLEN LAST NIGHT
  71. sump gasket
  72. Hi there evry1
  73. Wet seat belt in my S2...?
  74. fuel accumulator? swirl pot?
  75. Charge or Inter cooler? :)
  76. oil pressurre
  77. S1 FUEL PUMP RELAY
  78. What colour ?
  79. escort mk 4 headlight
  80. fuel pump on an S1
  81. advice needed
  82. radtec incoolers
  83. st 170 brakes
  84. In car boost adjuster fitting Q's
  85. what tires
  86. HELP !!!!!
  87. heeelp (up dated)
  88. turbosystems
  89. 18's on an s1
  90. fueling limits for boost
  91. oh dear- need a new turbo?
  92. Removal Of The ABS Module
  93. oil breather
  94. Upper Boost Limit.
  95. piper cams - good or bad please help!
  96. cossies discs
  97. Chrome inlet and throttle body?
  98. cossie brake conversion
  99. Strange Noise
  100. New Boy here
  101. xmas prezzie
  102. Hello to the newish RST owners?
  103. help needed
  104. S2 High Flow Water Pump
  105. must be tune up time
  106. Advice needed on fitting a 5th injecter.
  107. desperate
  108. Charge cooler plumbing advice needed
  109. s2 revving by itself and power loss?
  110. leaky series 2 ?
  111. s2 standard alloys x5
  112. Lowest springs for an S2?
  113. More adivce need if your so kind.
  114. New head
  115. Cam opinions
  116. Oil Change
  117. best tyres for s2 erst?
  118. standard boost pressure
  119. Flames!!!
  120. Oil Leak
  121. changing a fuel filter on a s2erst?
  122. unsettling thoughts
  123. White smoke
  124. need help
  125. erst s2 question
  126. s1 catch up
  127. New Engine Spec
  128. WHAT IS THE BEST OIL TO USE IN S2
  129. Alloys
  130. Mondeo 16" 5 spokes
  131. Cam change
  132. 3" goose
  133. temp guage
  134. pace
  135. Roof Skin
  136. Roof Skin
  137. Bad idea?
  138. Escort Cossie Wheels on a S2
  139. boost Guage PIPE
  140. gearbox and driveshafts
  141. !!!Breakin B19-TRB!!!
  142. cossie management?????
  143. Best braking setup on ERST?
  144. just bought my first rs turbo
  145. Turbo gear box.
  146. A little help to a foreigner!!
  147. keeps stolling
  148. What Dumpvalve?
  149. help i need 3"polished full cage
  150. series2 erst sunroofcage removal
  151. ERST doesnt seem to want to warm up...?
  152. Fuel filter from XR3I and RST the same?
  153. Boot pump lifter question!
  154. XR3i stats compared to RS
  155. Electric Window problems
  156. earls turbo oil feed pipe with or without filter?
  157. temp sender???
  158. ESCORT S2 WHEELS
  159. how much you spent on your erst
  160. best battery for the s2 erst?
  161. does anyone know of any s1/s2 going cheep(project car)
  162. Cossie 4X4 intercooler in an S1?????
  163. s1 servicing
  164. What wheels should I get for the S2?
  165. S1 Turbo sunroof problems
  166. low comp
  167. temp gauge
  168. My series 2
  169. four spoke rs steering wheel
  170. Can you still buy 90 spec bumpers new?
  171. rolling roads and set up of a erst whats involved?
  172. Piston Question!
  173. Carbon bonnet?
  174. head depth
  175. Strange noise
  176. Can anyone out there help me!?
  177. ZVH conversion
  178. more power
  179. Do I need a chip or not!!!
  180. Out of fuel past 1/4 Tank
  181. Rockers
  182. Cossie Management
  183. Rolling road results and some pics of the motor...
  184. Need some dark blue leads!
  185. Oil Change
  186. Just ordered a new engine mount, only £28!
  187. Finis code for Alternator Belt
  188. How do i???????????
  189. New alternator?
  190. Sunroof problems!
  191. What Chip to run?
  192. Sold my Sapphire and taking either a S1 or S2 in P/ex.
  193. amal valve
  194. jag smashed my s2
  195. electric wing mirror question
  196. Cossie brakes on a S2
  197. Not enough BOOST!
  198. 285mm on a S2
  199. Piper cams
  200. What suspension for S1 ??
  201. fused battery leads
  202. What you recon i could make?!
  203. S1 arches onto a s2!
  204. Painting Turbo
  205. Light problem!
  206. 4x4 t3 turbo.
  207. Anti Roll Bar
  208. cossie brakes on s2
  209. Pedal To The Metal!
  210. Focus Clocks In A Mk3 Or Mk4 Rs turbo
  211. Wheel question.
  212. Overboosting @ 14PSI
  213. series 1
  214. thicker anti roll bar?
  215. valve guides....
  216. Anyone use G Max lowering kit on S2?
  217. Roll Cage
  218. Lack of side light when ignition off
  219. Cosworth 4pot brake conversion help?
  220. lets se some flames :---)
  221. newbie here
  222. what could they have done to my s1
  223. hot start probs
  224. Been offered a S2...
  225. series 1 custom and non custom
  226. c reg non custom s1
  227. No fuel!
  228. Whin'ing noise on start up!
  229. fuel computer
  230. opening rear windows.
  231. No amal valve on my turbo?
  232. just curious:):)
  233. Pain to start my hot RS. Having Cold start valve plugged in.
  234. rst accelerator cables
  235. Newbie questions!
  236. different kenlowes
  237. What brakes to run???
  238. Hot running S2
  239. What do you think....as a joke of course!!
  240. High Fuel Pressure?
  241. poly bushes
  242. overheating s2
  243. boot syickers on the series 2.
  244. ERST Boost
  245. Driving my RS is like learning to drive all over again!
  246. Where is the best place for interior bit and pieces
  247. Are Power Engineering any good?
  248. Fuel Prob. :(
  249. Lewis' RST!!
