gearbox and driveshafts
need new ones, can i fit any mk4 escort box and shafts, i know i'd lose the lsd but money is short and i'm fed up on shelling out on rs ones just for them to blow-up.
Any gearbox from a cvh or a 1.8D will fit. The driveshafts will fit to, if you have removed the A.B.S. system, otherwise you will need the RsTurbo or orion 1.6 ghia with A.B.S. shafts, because the belts are atached to the driveshafts. About the box, think, if the tone that was built for the car brakes in a short amount of time, imagine what will happen to a weeker one...
cheers m8!
cheers m8!
You can buy just any gearbox and swap the LSD over. This is easiest with a box that already has a 8-bolt crownwheel. Otherwise your're looking at getting the crown wheel redrilled and tapped.
Originally Posted by JesseT
I am 90% sure thath the Escort mk5 diesel and 1.8 zetec (not 130hp) BC gearboxes have the 8-bolt crown wheel. If somebody could confirm, that would be brilliant.
