Lack of side light when ignition off
Car just failed mot with side light not working with ignition off. But it does work with ignition on. Any ideas?
thanks
thanks
well swapped the light switch over and no difference, had a play about in the fuse box and managed to get one light working on main beam, so im pretty sure its the relays now, so which relays are where in the fuse box? the two at the back right are they the main beem? relays are on order £7.50 each!
