285mm on a S2
Old 28-10-2003 | 07:28 PM
RS-adam's Avatar
RS-adam
Default 285mm on a S2
hi..
im going to upgrade my brakes.. im going for 285mm
any of u got any good experience wit this... does it improve the braking A LOT or
and what should I go for.... Mintex, Pagid, Red Dot, EBC e.t.c
and doesent it give any probs when the caliber, ánd brake pads, only are made for 260mm????
Old 28-10-2003 | 11:34 PM
wildheart's Avatar
wildheart
Speak to Mike Rainbird,he can get you caliper spacing kits to fit 2wd cos discs so you can keep your standard calipers.
Make a big difference because there is more clamping force.
Go for Mintex 1144 pads
Kris.
Old 29-10-2003 | 08:39 PM
Exeter J's Avatar
Exeter J
I've got this conversion on mine and it is well worth the dosh. It stops the fading and gives more brake feel. Don't go for race/kevlar pads if your using for normal/fast road driving rather than racing - cos these take a while to heat up to working temp and in normal town driving you can find yourself closer to someones rear end than you'd like to be! MAD-FOR-IT on 01579 320070 also do the spacers and some rather nice drilled disks to go with them for Ł145 - see http://www.mad-for-it.com/page3.html
Old 29-10-2003 | 09:31 PM
wildheart's Avatar
wildheart
I wouldnt recomend drilled discs if you give your car a thrashing,they have been known to get heat fractures quite often
Old 01-11-2003 | 08:05 PM
RS-adam's Avatar
RS-adam
tanx m8's
I already got a caliper spacing kit... so i only need the discs and pads....
Old 01-11-2003 | 08:30 PM
ADSRST's Avatar
ADSRST
the best pads ive ever used are mintex 1155 they are not recomended for road use but ive never had fade with them
blunty 07
31-03-2014 02:00 PM
mr west
25-08-2012 02:59 PM
Ratty
19-06-2010 05:34 PM
muz
06-03-2009 03:48 PM
Quick Reply: 285mm on a S2
