285mm discs
285mm discs
Hi
i belive i have 285mm discs and 4pots on my S2 (was on the car when i brought it so not messured them) but they are warped to f**k and i'm also not happy with bite from cold.
just wondering where to buy new discs and pads from and what ones do people recomend?
thanks
alek
thanks
alek
Spanner monkey
As above, sounds like you have a 2wd cossie set up. 283mm discs. I had drilled discs on my old series 2 with standard pads, they were awesome. I did try ferrado ds2000's but found i couldn't get the heat into them with normal driving and the stopping was shite untill warm, so went back to standard again!
Don't ask - I don't know
Personally I use drilled and grooved discs which dissipate heat alot better, so as long as you go for those and a half decent brand you'll be fine. As above, they're 283mm discs and they fit under standard rims (just !). Shop about for the best price ! I've also got standard Ford pads - do the job for me !
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
