rev limiter
Old Jan 12, 2004 | 12:36 PM
RS-adam's Avatar
RS-adam
Default rev limiter
how can I get me S2 to rev up to 7000 rpm
can u buy a chip that will du this??
Old Jan 15, 2004 | 06:54 PM
Rick's Avatar
Rick
No, because there are two limiters - ignition and fuel.
The fuel ecu has to be modified.
And 7000rpm is pointless on the vast majority of RST engines, as there is no power there.
Old Jan 15, 2004 | 07:28 PM
JesseT's Avatar
JesseT
In the far corner of the fuel ecu are two identical parallel coupled red capacitors. The sum value of these define the fuel pump cut-off limit.
Old Jan 15, 2004 | 07:29 PM
JesseT's Avatar
JesseT
Oh, and that's valid only for the S2. In a S1 it's the fuel relay that does the same job.
Old Jan 16, 2004 | 04:47 PM
WutangRS's Avatar
WutangRS
Default rev limiter
ive had the limiter removed from mine and yer its in booth ecu's
when it was on the rollers it made 194bhp at 6840rpm
u relly need a balanced bottom end to be ok around there. standard bottom ends get dodgy just after 6000rpm
TPM961
Jan 15, 2018 10:50 AM
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
