Anti Roll Bar
If you wanna upgrade the front anti roll bar - you could use a Series 1 item - these are much stronger/tenser - I think they fit straight on (if you get the mounts also). Try calling Colin at Mad-4-it on 01579 320070 - he'll advise you what you need to convert it, some in stock and has the ajustable block thingies for them
The S1 bar is much softer! I know because I'm using one. It is often praised because it has separate reaction bars and therefore it locates the wheels more firmly. BUT, the antiroll bar is much softer and will make the car lean more in the corners.
07-10-2015 12:56 PM
