Whin'ing noise on start up!
Old 02-10-2003 | 11:21 AM
lamar69er's Avatar
lamar69er
Default Whin'ing noise on start up!
Over the last few days in the cold mornings ive had a whin'ing noise on start up! So wot things can make horrible noises? i was thinking it might be the starter motor, or the alternator?
Today it did it when i flicked the ignition on without me starting the car, so whats live or moving when the ignition is turned on? As soon as im off the drive the noise has gone, but its really starting to bug me now! its a horrible whin'y scraping noise!
Old 02-10-2003 | 11:24 AM
B19-TRB's Avatar
B19-TRB
u aure it aint ur fuel pump gettin noiser!?
Old 02-10-2003 | 11:31 AM
Exeter J's Avatar
Exeter J
So its not doing just whilst the starter motors turning over? Just says cos i've changing my starter before and if it doesn't sit quit right on reinstallation it can make a horrible grinding noise on turn over... but it sounds like it is this as it does it before starting??
Old 02-10-2003 | 11:42 AM
lamar69er's Avatar
lamar69er
the fuel pumps brand new! and is every so quite when the engines running!
It dosnt apear to make the noise when i turn it over, thou sometimes the starter motor seems to stop, then if i retry again it turns over first time! bit weird!
how much are new starter motors? wheres the best place to get them from?
stevo's Avatar
stevo
id say fuel pump!!!!
Old 02-10-2003 | 12:19 PM
lamar69er's Avatar
lamar69er
hmmm... dont think its the fuel pump! il check where the noise is coming from tomorow morning!
Old 02-10-2003 | 12:28 PM
paul cox's Avatar
paul cox
if its a belt thats worn - see if the noise stops when you spray it with break cleaner !!!!
the starter could be holding in - try cleaning up the conections
fuel pump - may be,they are all ways noisey !!!
Old 03-10-2003 | 09:03 AM
lamar69er's Avatar
lamar69er
well I was all ready to listen to it this morning and find out where is was coming from, and sod me it didnt do it! pain in the arse! bloody RS's!
Old 03-10-2003 | 10:32 AM
paul cox's Avatar
paul cox
thats because it was a bit damp this morning ???
i'd say then,its gotta be a belt then (perhaps)
Old 03-10-2003 | 10:41 AM
lamar69er's Avatar
lamar69er
yeah, ive got a new fan belt to put on, im gona drop the alternater off and give it a clean out, might even get it recon'd yet, a place near me does it for about Ł20 on the cheap!
Old 03-10-2003 | 12:13 PM
paul cox's Avatar
paul cox
there you go then - i'd say that !!!
my alternator makes a noise in the summer,as it dry's up.
try sparying brake cleaner on the belts - if the noise stops - there's ya problems
for a temp measure - rub wax crayon on the v part of the belt.
Old 29-10-2003 | 06:13 PM
with past problems.id say that noise is crap inside your fuel tank blocking outlet to your pump from time to time.
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
xrmalin
13-09-2015 06:52 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
stevierob
07-09-2015 07:09 PM
kevin36
02-09-2015 06:24 PM
Quick Reply: Whin'ing noise on start up!
