oil breather
oil breather
hi i got a bailey oil breather and want 2 fit it do i need ne extra pipes
how easy is it 2 fit and how do i fit it i know how 2 bolt it on and roughly
what pipe goes 2 what but if u could help me much appreciated
theres an out let on the rocker cover where you mount the thing the pipe is short and is a bastard to get in make sure you but this pipe on befroe you bolt it up
then the left side outlet on the rocker goes to the the other top outlet on the breather
theres 2 outlets on the bottom one is to the oil return, back of block, andother is to the meter head you will see when you pull the standard pipes off the car
mark
mark
Yep - Amber performance do the proper fitting kit for £28. See...
http://www.amber-performance.co.uk/site/ford/bailey.php
