ERST Boost
Had a couple of boost gauges on my car to check her over and found that she was boosting up to 4 PSI and that was it. Any way checked for leaks - none found! Any way if you rev my car really quick up to say 2500 RPM and let off the dump valve gives up a big chirp. Never seen this when car not underload. Any way checked over the engine I have got in my car has had the Amnal valve chopped so I just have a tube from the Charger to the Actuater. So I carefully adjusted it turn by turn. Any way I got it now so if you rev it and let go there is no dump valve noise but there is a wicked chatter from the waste gate. Boost sseems about 8 psi so happy with that. But why is the dump valve not dumping now??
Cheers as always viewers
I ain't to hot on this but a similar thing happened to mine. I found that my dump valve was stuck open/closed (can't Remember) and it used to flutter. Try changing it and see if that works... Sorry if this isn;t any help
dump valve will work not moving u normally have to rev it quite high.
depending on ur boost and when it kicks in. i found i could hear a gud dump about .7 to .8 bar anything over 1 bar is bloody loud.
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
