- Β&Μ short shifter
- Fitting a FMIC without a setup.
- RS Turbo Efi conversion
- Silicone hose?
- Series 2 Turbo
- best place to port a cvh haed
- best cam for a big power cvh
- gotec mapping
- Ign timing - think this might have already been answered! sorry!
- Double Springs
- Oil cooler kit
- Any 1 got a passenger side genuine ford headlight protector for sale or dont want???
- wheel colour suggestions
- additonal cam oiling
- rst.... tlc
- Who has jamsport manilfold
- blacktop engine mounts for the rst s2
- Thinking of selling my S2 - valuation please?
- can anyone tell me
- just put my s2 away for winter
- S2 wing mirrors
- S2 drivers footwell soaking
- oil separator and springs
- 90 spec wiper stalk
- tyre queries?
- Boost Air Temp
- Front inner wing bumper mounting
- its started the continuing story
- its started part 2
- st170 turbo
- its started!
- rst s2 wont fire ??????
- erst needing welding, surely not!!
- Zvh piston choice?
- hands up you footwells get wet when it rains!!
- another bonnet pin question
- Rear escort rs hub?
- quick turbo question
- boost fluctuation
- RS turbo coversion list?
- carbon bonnet
- RST gearbox headache
- hmmm any idea's?
- Help needed! my ERST cuts out when driving along.
- My old S2 (for anyone intrested) lol.
- fuel gauge not working.
- Nasty vibration on s2
- Escort RS Turbo Jerky.....
- clamps
- car wont fire ????????/
- turbo heat shield
- mtx box
- 90 spec boot sticker
- Bought my first ERST
- mfi crossover pipe with efi ??
- anyone running the phase 4 newman cam??
- Gearbox choice?
- Bonnet pin's
- s1 rs turbo oil filter number????
- weight and dimensions of a mk4 tailgate?
- no spark on mfi 1.8 zvh
- Plugs, leads and oil :)
- How long
- Lets see your engine bays
- ignition timing
- bargain!!!!!
- rs turbo or zvh into a diesel mk5/6 van?
- Cant Figure Out Whats Wrong...What Do You Think??
- anyone know G333ajh??
- Misfire
- upgrade / modification
- running one fan
- trick bits
- new tailgates rs
- 16" wheels
- Un smooth Boost
- backfire when i turn s2 off after a run.
- fitting grs !!!!!!
- curious air line
- Is there anyway of telling what "stage" your turbo is? PICS UP GUYS
- cross hatched cylinder head
- suspension???
- exhaust gasket and bad compression
- Little update.....
- s2 rs turbo not boosting :( help please!
- Little update from Stu Collins 352bhp @ 22psi
- How do I know if I have an LSD 'box
- battery light on
- Bailey dump valve
- fuel ajustment on the Potentiometer
- thout shall not:!!!!
- OFAB chip setup
- rs turbo clocks
- cts stage 2+ gearbox
- speedo drive problem
- s**t idling!!!!!!!!!!!!!!!!!!!!!
- Electric oil pump
- 3 inch mogoose
- Fuel computer
- Leccy window problem
- top end missfire's
- 3dr bodykit?
- Accralite 1.5mm oversize pistons
- pics of erst track slags ???
- Clockwise or anticlockwise?
- measurement required please
- braking down
- Wiring issue,
- Help! Rev counter not working and battery light!
- Bleed valve
- mgasquirt on rst
- efi s1 cabriolet wont rev past 3000 help
- Amal valve
- turbo removal guide ???
- Fitting a oil return stub to a EFI block
- How Long have you had your RST?
- anti roll bar
- starter motor
- Water Swirl Pot
- What fan is this???
- b&m quickshift is it worth doing ?
- 1900 CVH turbo
- relay clicking???
- central lockin
- xr3i inlet
- Changing bushes...
- What FMIC?
- Oil separator
- Crank pulleys ?
- Escort Turbo Car Mats
- Oil Pressure?
- annoying squeek...
- CVH Cranks and EFI Blocks......
- Stuttering on boost help!
- Should my S2 have central locking?
- mk4 door handle (cabriolet/hard top)
- Inlet Plenum question
- What do you think the power is?
- Dual Spring Valve Stem Seals
- Petrol tank
- Dump Valve or not?
- My S1
- wire s to fan
- 6 speed into rst
- Scorpion bk/box on magnex
- Wheel spacers, hubcentric...by how much??
- Camshaft Change
- Few pics of the old bean!
- loom
- Under bonnet ford decal / sticker set
- Timing advance or retard on a...........
- Wtf
- Classic ebay listing!!
- tubular manifold and fmic
- Anyone had any experience with these Rods?
- MK4 rst rollcage
- boosting problems
- Bosch starter motor
- kent cam?????
- Tesco 99 ron
- Turbo question :)
- gearbox !
- 5th gear
- bit puzzeld
- oil breather
- changing gearbox advice...
- flocking in westyorkshire
- Centre Console!
- alcon 6paddle 215mm clutch good or bad!?
- steering racks????????/
- handbrake cable
- FAO Rick
- RS1600i rocker cover on an efi car
- do shells need to be run in?
- Trick of the trade. Fuel Pump relay...
- how hard to run cosworth L8 management on black top zetec turbo?
- is this a good engine spec ? how much power am i looking at ?
- Desperately need help
- where can i get a new under fuse box panel
- Who has actually snapped CVH Con Rods?
- silver or black top for zvh
- For anyone interested in a hydraulic clutch conversion.... NEW TIP! 18.04.10
- where from !!??
- Oil light on/off at times although i KNOW the oil is correct
- Battery light on?!
- Weird Battery Problem
- help! what throttle cable is used for cossie managed escort turbo
- S2 rear decal location needed pls. . .
- lights come on when i brake??????????????
- 1mm spacer on cossie front calipers, why?
- carpet
- Cosworth calipers
- EGT temp range
- 4x4/fwd/rwd conversion/converters
- turbo on its way out???
- water leak in boot
- Making Inlet manifold
- aerial
- oil?
- FTAO Crazycage
- turbocharger help needed
- my new manifold
- oil breather/ seperator
- Megasquirt and 50 degrees advance
- S2 Original Stereo
- Made a shocking discovery today!!!
- Have you got starting problems? Helping topic
- mk4 Rear turrets rubber bush.
- which sump seant is best
- What head for zetec turbo
- Breathing. I think?!?
- s2 breather question!!!!
- Car has been on the RR
- Perspex Windows
- clicking igntion
- rev limiter
- 170 mph clocks
- Removing rust inside sunroof tray.
- pic request / engine bays
- RS Turbo S2 starting problems
- this car
- what seatbelts fit???????
- anyone breaking a mk4 escort?
- s2 starting problems
- What do you think is the best set of coilovers for a trackcar!
- Can anyone show me Red RST on black wheels
- Can I see you dark/ black interiors
- Escort rs turbo running hot !!!!กกก
- Thinking about buying an escort RS Turbo
- cant figure this out (handling)
- servo on the s2, any other options
- Pic request please
- Could my clutch be on its way out?
- Spraying diamond white paint
- ahmed bahjoo chip, opinions please
- No spark (EFI)
- focus rs brakes
- bonnet piston instead of pole ??....
- Water in passenger footwell....
- rear s2 brake shoes which ones?
- what is my roll cage worth?
- anyone know what might cause this!
- brake problem, after i bled system
- Things not going my way again........
- Its a wired one.
- s2 rst turbo few problems can any 1 help
- yey or ney
- I need help!!! Were does this go ?????
- std clutch size??
