ignition timing
Old Nov 8, 2009 | 10:12 PM
RSargie's Avatar
RSargie
Default ignition timing
just woudered what sort of advance people are running with there ignition timing on modified engines? and basic engine spec thanks
Old Nov 8, 2009 | 10:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
IIRC 8degrees BTDC on MFI is rule of thumb, checked with a timing light, the engine up to temp, and the vacuum hose off the ECU and blocked off (inlet side, not ECU).
Old Nov 9, 2009 | 06:08 AM
ROB7656's Avatar
ROB7656
thought it was 12 degrees btdc for standard
Old Nov 9, 2009 | 07:22 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah it is for a standard car, for engines running more than standard boost I would go with 8degree BTDC, until I had it RR'd.
Sorry should have specified I was talking bout modded engine lol
Old Nov 9, 2009 | 12:06 PM
RSargie's Avatar
RSargie
surely the more fuel and air the more advance you would need as there is more to burn?
Old Nov 9, 2009 | 02:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The exact opposite mate, the more fuel and air there is the more it is compressed the faster and hotter it will burn
van_dogg_pavvy
Mar 3, 2016 09:30 AM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
