speedo drive problem
right the speedo was bouncing around last night, went from 60 to over a ton in about a second, was doing this for a bit and then stopped working alltogether, the end of the speedo drive is knackered, now for the problem, the end of the roll pin has been snapped off and is flush with the box
, has anyone got any ideas on how to remove the pin without removing the gear box?
cheers, neil
, has anyone got any ideas on how to remove the pin without removing the gear box?cheers, neil
