FTAO Crazycage
Old 23-10-2009 | 10:48 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Default FTAO Crazycage
Hi mate, is this where you drilled your 2" hole for the clutch master cylinder? Did you remove the pedal box first or just drill through that as well, and what about bolting it on can I use the top pedal box bolt and then just drill a hole for the bottom one?
What/how did you do yours?
Cheers!
Old 23-10-2009 | 05:10 PM
crazycage's Avatar
crazycage
yes thats about the right place but you need the master cylinder first.
measure down from the top bolt hole on the new cylinder and then do the same on the car measure down from the top bolt hole and drill it out . for the bottom bolt hole i welded a bolt onto the bulk head for it.
and yes you need to remove the peddle box to drill the 8mm hole in the peddle and i think i had to trim a little off the corner of the peddle box but you will see if you have to when you try to fit it back on.
Old 23-10-2009 | 05:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ah cool!
Yeah I have the master cylinder, just wanted to be sure before I went hacking away! lol
Then drill the 8mm hole 55mm down from the pivot point, is that meassured from the centre of the shaft that the pedal pivots on, or from the 'edge' of the hole that the shaft slides through in the pedal?
Cheers for your help!
Old 23-10-2009 | 08:19 PM
crazycage's Avatar
crazycage
Originally Posted by Karlos G
Ah cool!
yes 55mm from centre to centre
Old 24-10-2009 | 11:54 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Sweet! Cheers!
Steve Escos
31-07-2015 06:21 AM
RUBY123
24-07-2015 10:10 AM
crazycage
20
31-01-2007 03:45 PM
Quick Reply: FTAO Crazycage
