trick bits
Old Nov 8, 2009 | 10:02 AM
RS1HEN's Avatar
RS1HEN
Default trick bits
i had the wheels off the car yesterday, was doing a bit of cleaning and and stuff, and was quite alarmed to find the inside edge of both front tyres was quite worn.
the car is on 16" with 205, 40 tyres, koni top adj.
i would like to be able to adjust the camber, possibly the toe, not sure if i can do the castor, as i haven't seen any concentic top mounts for an rst, and not only that i don't really want to have to get coil overs
i was wondering if anyone knows if you can still get adj tcas, preferably rose jointed.
and if theres a relocation kit for the roll bar, with perhaps blades and drop links?
has anyone fitted compression struts to thier rsts?
Old Nov 8, 2009 | 10:05 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
adjustable tca's are availible from burton power, as far as i'm aware, and so are top mounts, if not from rally design.
Old Nov 8, 2009 | 10:17 AM
haz87's Avatar
haz87
Compbrake do them as well
Old Nov 8, 2009 | 10:25 AM
RS1HEN's Avatar
RS1HEN
still waiting fot the burton catalouge
will check on those top mounts, cheers lads
Old Nov 8, 2009 | 10:38 AM
RS1HEN's Avatar
RS1HEN
should of put "eccentric", not concentric, oops, me failing memory,
all the rd stuff is for mk2's
gus's Avatar
gus
i had some rose jointed tca's from burtons and backed them
they was horrid
got a pair from martin at mef in the end (he no longer does any rst stuff tho)
still thinking about the bladed arb myself
Old Nov 8, 2009 | 10:48 AM
RS1HEN's Avatar
RS1HEN
they was horrid
are you still using the tcas?
RD do a bladed arb for the sierra, but, iirc they were reputed not to be very good. but for a road car i think they may be fine, though i think there would have to be some modification involved?
i did have baldes frt and bck on my old sierra, but it wasn't rd.
they were awesome... on soft, when you jacked the car up, they wheels would droop about 6"
on stiff it was an 1", incredible bit of kit
Old Nov 8, 2009 | 11:04 AM
RS1HEN's Avatar
RS1HEN
just found this, thanks to haz87 for orginal post!
http://www.compbrake.co.uk/SUSPENSION6.html
http://www.compbrake.co.uk/SUSPENSION8.html
still looking for an arb
gus's Avatar
gus
yeah using the mef ones now
i have the compression struts from mef also
think its the eccentric top mounts that i have (concentric are the big ones with a million holes in yeah?)
couldnt tell ya how it all works tho, pushes in and out of the garage real nice
Old Nov 8, 2009 | 11:06 AM
gus's Avatar
gus
i know a fella who has put the rd bladed arb on the rear of his s1
his not too impressed with the kit itself but it works for him
really cant remember what he is doing on the front
think mine will be custom made jobbie i think
Old Nov 8, 2009 | 11:09 AM
RS1HEN's Avatar
RS1HEN
you've got mk3/4 comp struts?
yes the ecccntric ones have the locating hole, off centre....with the billions of holes, lol, for angling the struts castor!
Old Nov 8, 2009 | 11:15 AM
RS1HEN's Avatar
RS1HEN
thats made me think about the back as well now, bugger!
yeah, not sure about the front arb, the seirra one is designed to go behind the engine, with struts in front, obviously back to front with the esc, and i don't think the blades will be long enough????
Old Nov 8, 2009 | 11:17 AM
gus's Avatar
gus
if yours is just for road why not just use the rs16i arb and crossmember?
thats gotta be better than the standard s2 one
Old Nov 8, 2009 | 11:29 AM
RS1HEN's Avatar
RS1HEN
not so familar with rs1600i stuff?
wouldn't it be quite a bit of work to fit it?
i was more intrested in seeing if there was a arb kit about,
would be great for track days when/if we do any
the whole thread started off as an idea to see how i could adjust the camber of the front wheels, and now it seems i'm spending vast slabs of gold to save tyre wear lol
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
chowfornow
Sep 19, 2015 10:47 PM
