EGT temp range
Old Oct 24, 2009 | 02:50 PM
Chris69's Avatar
Chris69
Default EGT temp range
I've recently managed to get my EGT guage to start working on my VEMs AFR/EGT and i was wondering wot sort of values I should be seeing and a rough guide of the max temp that i really wanna see when hard on the throttle??
went for a quick run and its 3/4/500 degrees c when just driving normally and rises to a max of about 750 degrees c with prolonged time at full throttle.
My engine is a standard EFI 1600cvh running a bar of boost with 195 chip and beiges.
The probe is located just after the turbo in the downpipe.
Old Oct 24, 2009 | 03:42 PM
gus's Avatar
gus
yes i shall be needing to know this also
Old Oct 24, 2009 | 05:45 PM
wing's Avatar
wing
that sounds ok mate, mine goes to 850 but that's before turbo, you don,t want anything above 800-850 after turbo
Old Oct 25, 2009 | 10:41 AM
Chris69's Avatar
Chris69
cheers mate, I remember reading about not wanting it to go over 800 or so but wasn't sure if that was before or after the turbo.
temps go down pretty quick once off full throttle so i spose thats a good thing.
Old Oct 25, 2009 | 05:27 PM
Rick's Avatar
Rick
800-850 after turbo ROUGH max. what is afr?
Old Oct 25, 2009 | 05:41 PM
crazycage's Avatar
crazycage
its air fuel ratio .. god and i let you map my car lol.
Old Oct 25, 2009 | 05:48 PM
JamboRS's Avatar
JamboRS
focus rs 1672
think he was asking what the afr is not what it means
Old Oct 25, 2009 | 06:01 PM
crazycage's Avatar
crazycage
really ??????????? fuck me i never new.
Old Oct 25, 2009 | 06:15 PM
haz87's Avatar
haz87
As above, I'd be concerned seeing anything over 850
Old Oct 25, 2009 | 06:16 PM
Chris69's Avatar
Chris69
thats ok then, so as a rough guide aslong as i'm not getting too close to 800 or over it then it should be fine.
the AFR is steady @ 11.7/11.8- sees more like 12 on a cold morning though!
Old Oct 26, 2009 | 12:54 PM
sas's Avatar
sas
should be good!
Absolute max 850 deg C.
Mark RS
Oct 12, 2015 06:01 AM
rsguy
44
Sep 29, 2015 03:29 PM
