RS1600i rocker cover on an efi car
As title has anybody used a finned rocker cover whilst running EFI? If so how did you get around the height of the cover, have been looking at having a spacer for the inlet made but still don't think it will work.
don't do it, it has been done, fins cut and cut out done to cover and tig welded a plate in to make a groove in it for cross over pipe.
i thought about doing the same, but the cost would have been daft, so got an alloy standard shape one, so looks good and won't warp like the mild steel ones.
i used to run a 16i cover, i cut the center pipe off the cover and welded it on the side, got rid of the fins to the right hand side of the cover then ran a 90 elbow off the tb.
youll find the pics here
https://passionford.com/forum/pictur...oured-van.html
