rs turbo clocks
Old 04-11-2009 | 08:41 PM
studabear's Avatar
studabear
Default rs turbo clocks
I'm told I need a efi rev counter for when I fit cossie management with wasted spark, Can the rev counters be removed from the instrument panel and switched?
eg- efi rev counter into mfi instruments?
Or will I have to fit the full efi clocks set up and is it a straight swap IIRC the fuel and temp gauges were swapped round on some models,i'm unsure which??
Cheers in advance
Old 05-11-2009 | 06:33 AM
Chris69's Avatar
Chris69
Yes, you can just remove the rev counter from a late mk4 EFI car and use that- the whole unit/pod can be taken apart and each instrument can be removed individually.
I have an90spec EFi Xr3i rev counter in my S2 the rest is mfi stuff and it works fine on frst management
Old 05-11-2009 | 06:57 AM
Zetecfiesta's Avatar
Zetecfiesta
yeah you can dismantle them, ive just bought a set of clocks for that purpose! you can remove the revcounter as a whole unit or you can remove it from the facia and fit it to your original facia, thats what im doing as the paint is all peeling on the rev counter face i bought.
Old 05-11-2009 | 10:51 PM
studabear's Avatar
studabear
Cheers guys, I best get some efi clocks organised hen to steel the rev counter
Old 06-11-2009 | 10:31 AM
Zetecfiesta
i know of a set of clocks with lockwood dials on that are efi? i didnt get them though cause i wasnt sure they could be dismantled.
Old 06-11-2009 | 03:51 PM
muz's Avatar
muz
Wye Valley Hardcore
I'm still interested in the Cosworth speedo. Anyone done this?
JK12
33
26-04-2021 12:09 PM
RSBryden
06-09-2015 08:39 PM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
Quick Reply: rs turbo clocks
