st170 turbo
silver top sump fits, you need the silver top pickup, but the black top sump is much better, just need to cut it a bit if u are using a front starter.
ST170 springs are stiffer than normal zetec, the americans get about 20psi out of them, but you're better to uprate them.
your better of using a standard black top head with standard cams but with uprated springs with a custom inlet and this is good for 350 bhp, and if using focus rs box then use black top sump as it uses the extra holes
i had really bad valve float at 12psi on a standard st170 head. a blacktop will be much easier to get the power from and map.mine is over 350hp on a standard head and cams with a set of up-rated valve springs.
p-s really dont see why people want to go down the st170 head when the blacktop is sooo good.
Guest
Posts: n/a
It's fine use it
![](https://passionford.com/forum/images/smilies/roi.gif)
will let you have a go at central day if your there and you can see for your self how it feels compared to your engine .
well i have a silver top already with uprated area six valve springs,but the st170 ports are much bigger and been told these are good for 400+,also the blacktop heads are supposed to be much better than the silvertops, i also want to run a decent gearbox a focus rs one if i can get hold of one
what power do you want ??
i would just build a blacktop i really dont see the need for a st head .
i have been in a mates genuine 280hp 1.6cvh, and owned many fast cars myself including a 320hp rx7, but i am a ford man and love the agressive feel of the rst what no other car gives,obviously i have never had a 300+ rst so im building my ultimate with all the right bits,thankyou crazycage your a very helpfull chap,is there any chance i could run my silvertop area six valve springs in the blacktop head,if not where could i get a decent set for the blacktop
i'll second crazy been in his and first time we opened it up properly for a run on motorway to stretch it's legs we pulled to limiter in fourth which was like being on my bike and after run realised we were in fifth and had actually been at 7000+ revs in fifth gear which then made us realise just how quick it is and when it torque steers you need 3 lanes on motorway to keep it straight the jump from 270-280 t0 350+ is emense and for a road car 300 is plenty
if you want it for fast road use then perhaps 350 is slightly too much
but if you want it for making records like crazycage is going for then go for it mate.
sorry didnt see the strip and track post
Last edited by creator; 14-11-2009 at 09:38 PM. Reason: didnt see the above post about strip and track use
and that just goes to say what a genuine 350bhp fiesta goes like still getting sh*t loads of torque steer even with focus rs box decent suspension and custom bottom arms.
p-s mine isnt for setting any records its a every day road car.
oh right sorry i didnt realise you didnt have the arms on then mate.
and yeah i remember you saying about you using it daily but when your so close to the fwd 1/4 record and are just about to go ahead with getting a bit more power id say its about to set a record mate
lol
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
lol
project rs is talking about a late night mapping session about 9 months ago lol.
my 12.7 was set with about 310hp and by central day next year i should have about 370hp
9months ago kriky lol i think what youve said before tho you will get it as far as you can but when you cant get no more air into the engine from the turbo i think you will get bored and will have to go gt30
haha nah mate its an utter animal as it is.i think you should leave it as it is then i might be not to far behind you one the 1/4 miles when my engines built haha
Have a look on google at the st170 turbo's over the pond (search svt turbo)
They retain the vvt to get the turbo spooling up quicker and don't even change the compression ratio so get 300bhp at 12-13 psi on crappy fuel
and that's reliable too. Some are running 20psi on the standard engine puting out around 380bhp.
Jamsport do gotech ecu's that can retain the vvt (cheaper than omex and dta)
The only thing I'd recommend is ditching the standard inlet manifold on them as they can cause problems
i have mate and i wouldnt recommend it
![](http://i125.photobucket.com/albums/p63/crazycage/garyspics556.jpg)
yes i run a full 3" from the turbo back and it fits under my standard blacktop sump no probs.
Balls Deep!
![](https://passionford.com/forum/images/smilies/shocked.gif)
How fucking fast were you going??????
